68 front wheel spindle ?
Old Jun 16, 2012 | 04:03 AM
WESCH's Avatar
WESCH
Default 68 front wheel spindle ?
Hi
If I install for example 78 front spindles to my 68, do I also need to replace the bearing housing ?
The 68 has thinner spindles ( same as the C2 ) and as of 69, the spindle diameter was increased.
It is just a stupid idea from me that a thicker spindle will be better for my 68 BB with all the weight on the front.
Rgds. Günther
Old Jun 16, 2012 | 09:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by WESCH
...It is just a stupid idea from me that a thicker spindle will be better for my 68 BB with all the weight on the front....
Might be work you do not have to do. There were plenty of 65-68 big block cars with the same spindles as yours.
Old Jun 16, 2012 | 10:18 AM
Ironcross's Avatar
Ironcross
you will have tp change the hub also, in other words re-hub your rotor to any 69 or later
Old Jun 17, 2012 | 03:24 PM
WESCH's Avatar
WESCH
Hi
So it is not sufficient to replace only the spindles.
The hub needs to come as well from a younger C3 :
Thanks & rgds. Günther
To 68 front wheel spindle ?
