Steering Column Compatability
Old Jun 19, 2012 | 02:58 PM
mayor28's Avatar
mayor28
Default Steering Column Compatability
Forgive me for not searching this.....I was hoping to get a condensed response.
What steering columns will fit in a '72? Are they model year specific?
My friend asked me about them, he has a car that I am assuming has a broken or lost column......
Old Jun 19, 2012 | 06:30 PM
AF_Vette's Avatar
AF_Vette
1969 to 1976.
Old Jun 20, 2012 | 01:16 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
1976 will fit but it has a different steering wheel hub which will only accept the '76 vega style wheel, 1969-75 are all identical.
Old Jun 20, 2012 | 01:35 AM
AdamMeh's Avatar
AdamMeh
'77's are unique - save yourself.
Old Jun 20, 2012 | 07:47 AM
70BBvert's Avatar
70BBvert
78 - 82 will fit and they are 2" shorter than the original. BUT it will require modifications to the dash, steering column, lower cover, turn signal harness connector & the ignition switch connector has to be flipped.
At least that's what was required to install a 78 T&T column in my 70.
Jim Shea has posted information & papers on the steering column options and configurations
Jim
Old Jun 20, 2012 | 07:02 PM
72LS1Vette's Avatar
72LS1Vette
Jim
I put a 79 T/T column into a 72 and all I had to do was trim the bottom part of the upper column housing and re-pin the harmonica connector. I also extended the dimmer switch wiring harness and plugged it into the column to eliminate the floor switch.
Rick B.
Old Jun 20, 2012 | 07:52 PM
AF_Vette's Avatar
AF_Vette
Thanks for the heads up.
Old Jun 20, 2012 | 08:45 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Rick B.
Interesting.
I've heard that the later columns are lighter than the early C3 columns. Any chance you might know if that's true?
Old Jun 20, 2012 | 10:34 PM
Jim Shea's Avatar
Jim Shea
Here is the address of a paper that I authored on installing a 1977 thru 1982 T&T Corvette steering column into a 1969 thru 1976 Vette.
http://jimshea.corvettefaq.com/wp-co...ev23FE2011.pdf
Jim
Old Jun 21, 2012 | 01:22 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Originally Posted by 69427
Interesting.
I don't think its true, I just helped a friend to fit a '80 column into his '76 and I don't remember any weight difference between the two.
Old Jun 21, 2012 | 08:55 AM
Jim Shea's Avatar
Jim Shea
1). The earlier lock cylinder housings were zinc or aluminum diecast. The later housings were plastic. Some savings there.
2). Earlier steering columns had shift tubes and a lever with a cable to the transmission in order to operate the strg column/transmission shift interlock system. 1977 and later columns eliminated the shift tube and cable mechanism and just had a little finger trigger next to the ignition key/lock cylinder. Savings again.
3). Later columns had the headlight dimmer switch as part of the steering column. May have been a slight saving over a floor mounted switch?
Jim
Old Jun 21, 2012 | 10:06 AM
mrvette's Avatar
mrvette
YUP, I have a late shark column in my '72, yes the lower housing, and I put a piece of 3/4 wood between column flange and firewall on inside, this recovered some of the shorter length, I flipped the aluminum sliding flanges over so to still be able to bolt the column up correctly....
Dig this, I bought it for ten bucks, TEN bucks, and it was complete, was in a wreck, with no wheel on it, or key for it, I rebuilt it in '95, been on the road since....it drives a rack for the last ten years....
To Steering Column Compatability
