Windshield wiper issue
Old Jun 22, 2012 | 08:22 PM
78pace's Avatar
78pace
Default Windshield wiper issue
no luck using search .......On the 78 when I turn the wipers on sometimes they work fine. Sometimes they will move up just alittle then sit back down . I then have to move the switch up and down a few times and they will work fine. Problem in the switch? Or something else? Thanks in advance...........
Old Jun 22, 2012 | 08:37 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I'm going with the switch.... You can test the motor while on the car to eliminate it as the source. Just disconnect the wiper transmissions at the motor by removing the large nut shown by number 1 below. It is not the nut that holds the transmissions on to the bell-crank, but rather the main nut that holds the crank to the motor.
Here is the youtube testing video...
1969-1972
1973-1982 <--- 73-82 will test exactly the same as the 69-72 with the exception being the 12 volt input wire. You won't have one. All you need is to make sure the case is grounded and you apply 12 volts to the center terminal. Then jump the grounds as shown in the video and the motor should run.
Here is how to remove the switch from the dash pad.
Corvette Windshield Wiper Switch Repair 1978-1982
Here is how to repair the existing wiper switch:
Old Jun 23, 2012 | 07:36 AM
78pace's Avatar
78pace
Willcox.............Thank you ,I will try the motor test later this week. great video.
Old Jun 23, 2012 | 11:04 PM
0Willcox Corvette
Former Vendor
Thank you... post again if you need help.
To Windshield wiper issue
