sensor location
Old Jun 23, 2012 | 08:14 AM
garpearc's Avatar
garpearc
1st Gear
Default sensor location
where will I find the coolant temperature sensor on my 81, tks...ahead of time
Old Jun 23, 2012 | 09:29 AM
Tommy Almond's Avatar
Tommy Almond
Should be at the front center of the engine near the water hose connectior if you are wanting the one for the ECM reading.
Old Jun 23, 2012 | 11:03 AM
qwank's Avatar
qwank
Correct. Right front of the intake, next to the water neck
Old Jun 24, 2012 | 07:38 AM
Mgrad92's Avatar
Mgrad92
There are two. As previouslt mentioned , the one for the ECM is on top of the engine tight next to the thermostat housing. It has two wires, black and white. The other temp sensor is for the tremp gauge. It's located in the drivers side cylinder head between cylinders 1 and 3. It has a single green wire.
Old Jun 24, 2012 | 07:51 PM
SIXFOOTER's Avatar
SIXFOOTER
Nothing like a complete answer.
To sensor location
