1100884 alternator application
Old Jun 28, 2012 | 02:43 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Default 1100884 alternator application
I have a 1100884 alternator on my '69 (C60 and K66) dated 9J4 (September 4, 1969). I've read that this alternator was continued on to 1970 w/ same options. As far as the date code goes, how early of an alternator could a 1970 corvette have? Is September too early? When was the first 1970 model assembled?
Old Jun 28, 2012 | 02:56 PM
MelWff's Avatar
MelWff
if you have a 69 with that date code why are you asking about 1970. The 69 year was an extended run way into the end of the year, mine was made in November.
Old Jun 28, 2012 | 06:48 PM
LeMans Pete
I'm going to sell and want to know if it applies to the 1970 run as well, or with a early September date if it is limited to 1969 only.
Old Jun 28, 2012 | 07:08 PM
vettebuyer6369's Avatar
vettebuyer6369
Pete, the earliest 1970 productions were January 1970, I believe. This is consistent with the '69s running into December '69.
That said, I do not see why a September 884 alternator couldnt find its way onto an early 1970 with air or LT1... its only 3 months to January. I think NCRS would be comfortable with one through Feb or March.
Old Jun 28, 2012 | 07:23 PM
Mike Ward's Avatar
Mike Ward
884 alternators were used for the 1970 model year, all cars with AC or with LT1. NCRS judging rules accepts units dated up to 6 months before the car was built.
Old Jun 28, 2012 | 07:35 PM
LeMans Pete
Thank you Steve and Mike. Is it safe to assume 6 months for any component?
I didn't realize that LT1s were the only model that had TI.
Old Jun 28, 2012 | 07:53 PM
vettebuyer6369
As expected, on the same page with Mike
Generally yes, although Mike could chime in here, I think some parts can get even a little more leeway like glass? For example, I believe rear window dates on a convertible top can be a year.
Old Jun 28, 2012 | 07:55 PM
Mike Ward's Avatar
Mike Ward
Pretty well all glass can be up to a year, that's about the only component that 'the rules' allow beyond 6 months. Note that the vast majority of components were much closer to 2-4 weeks and 6 months is the very rare exception
Old Jun 28, 2012 | 08:08 PM
LeMans Pete
I am surprised by the 6th months. My alternator date is 9 days before my car build date. Less than 800 produced per week, I'm sure finding correctly dated units within 2-4 weeks, especially on hard-to-find pieces, can be near impossible.
Old Jun 28, 2012 | 08:10 PM
LeMans Pete
Thanks again for the details.
Old Aug 28, 2012 | 09:01 AM
LeMans Pete
Can you have a date that is too close to your build date? In other words, would a corvette's build date of 06SEP69 be too close to use this alternator?
Old Aug 28, 2012 | 11:51 AM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Three high amp alternators were used in 1969 for C-60 and/or K-66 applications... 1100825 was used very early in production, 1100882 was used for a short time after that, and generally, the remainder of the model year used 1100884. The earliest date on a real 1100884 alternator that I have seen is February of 1969 on a March 1969 car.
I wouldn't expect anything other than a 1100884 on a late 1969 Corvette. As Mike noted, typical spread on dates is usually in the two to four week range before final assembly, but the time can be longer.
Regards,
Stan Falenski
Old Aug 28, 2012 | 02:09 PM
LeMans Pete
So would a car lose points for a September 4th alternator on a September 6th car?
Old Aug 28, 2012 | 02:17 PM
Mike Ward's Avatar
Mike Ward
Maybe not- I'd probably just make a note on the judging forms, but where are you getting the September 6th date from?
Old Aug 28, 2012 | 02:46 PM
LeMans Pete
Mike - this is for a person interested in the alternator, I'm assuming he got it from the trim tag. Would a build date be listed differently on the tank sticker than the trim tag?
Old Aug 28, 2012 | 02:53 PM
Mike Ward's Avatar
Mike Ward
I asked because the car was not complete on the day the trim tag was stamped and attached. The body was not yet married to the frame at that point either. Cars were usually completed a day or two AFTER the trim tag date which would make the close timing of the alternator date a little more possible.
NCRS judging accommodates 'typical of factory production'. An alternator dated that close to the car completion date is not typical.
Old Aug 28, 2012 | 09:07 PM
LeMans Pete
Thats what I wanted to know, thanks Mike.
To 1100884 alternator application
