Wheel lug nuts help.
Old Jun 28, 2012 | 07:52 PM
Carlos840's Avatar
Carlos840
Default Wheel lug nuts help.
Hi all,
I need a bit of help, i need to change my lug nuts as most of them do not match and have lost most of their chrome and cannot find out what they are!
I know they are not stock corvette nuts but cannot source a replacement.
Here is a crappy cell phone pic (sorry)
As you can see the nut has a built in washer that has an angle in it, it is 40mm long.
Here is a pic of the wheel it goes in. (crappy old pic to, sorry)
Any help would be welcome.
Old Jun 28, 2012 | 08:03 PM
tnovot's Avatar
tnovot
I can't identify the wheel or lugnuts but would suggest you take one to a local auto parts store to see if they can match it with something in stock.
Terry
Old Jun 28, 2012 | 08:08 PM
Carlos840's Avatar
Carlos840
Terry
I live in Belgium, there is NOTHING in stock that matches, i need to figure out what they are so i can order them from the US...
Old Jun 28, 2012 | 10:17 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
do you have a local custom tire and wheel shop in the area?
Old Jun 28, 2012 | 10:20 PM
Carlos840's Avatar
Carlos840
No, as i said i am in europe and cannot find anything like that here...
Old Jun 29, 2012 | 12:00 AM
Vette5.5's Avatar
Vette5.5
I have an older(non Vette) car using ET Unilug wheels, with lugnuts similar to yours. Although a few years back, found some exact replacements from the Gorilla lug nut site. Maybe worth checking into.
Old Jun 29, 2012 | 02:34 AM
noonie's Avatar
noonie
Assuming you still have the stock lugs
http://www.brandsport.com/golugnuwhlof1.html
Old Jun 29, 2012 | 06:21 AM
Carlos840's Avatar
Carlos840
hanks, i have the stock lugs.
Unfortunately this website doesn't have anything that matches!
I need a tapered seat, but i need the nut to be 1.7" long and have the taper at 1" from the beginning of the thread...
Basically an extended mag but with a taper:
how can it be so hard to find nuts like that?
Old Jun 29, 2012 | 07:06 AM
noonie's Avatar
noonie
Are you sure the flat washer isn't just distorted?
I have seen lots of those, but never any with a shank and taper. That would defeat the purpose.
Perhaps post a better pic or one of the wheel seats.
Old Jun 29, 2012 | 07:12 AM
Carlos840's Avatar
Carlos840
sorry, i don't have one and don't have acces to the car right now.
The washer is definitely at a 60 degree angle, there is no way it could have been distorted so much! The wheel seat matches that...
Apparently the wheels could be western turbines, maybe i can use something else with them.
Old Jun 29, 2012 | 07:19 AM
noonie's Avatar
noonie
These are combo for ET wheels but the shank isn't that long.
Shank diameter may be different.
http://www.brandsport.com/grla-21138et.html
Have had lots of Western wheels, I think they were regular shank mag nuts.
If yours truly do have a proper 60° seat, then a conical nut will work as long as your studs are long enough.
Old Jun 29, 2012 | 07:27 AM
Carlos840's Avatar
Carlos840
I saw those but they only have .25" before the tapered bit, mine have 1" going in before the taper.
Isn't that going to be a problem?
Old Jun 29, 2012 | 08:47 AM
Mooser's Avatar
Mooser
The only thing I've seen that looked something like that was metric.
Any chance yours where changed since your "over there"?
There's a company called Otis co or Otis inc or something like that. They make lug nuts for European cars. Like Gorilla for Europe
Mooser
To Wheel lug nuts help.
