Quick Vintage Air Questions
Old Jul 4, 2012 | 08:55 PM
94hokies's Avatar
94hokies
Default Quick Vintage Air Questions
The PO half installed a traditional AC unit but never completed and was missing many parts. Figure while I have the motor out to do the TKO600 swap, I should just pull all that stuff out in prep for a Vintage Air at some time next year. So question is, can I just pull out the AC wiring harness to clean up the engine compartment and all the traditional AC vacuum tubing or is any of that reused by the Vintage install?
Thanks...
Old Jul 4, 2012 | 09:14 PM
oldalaskaman's Avatar
oldalaskaman
save the wires , lose the rest
Old Jul 4, 2012 | 09:18 PM
94hokies's Avatar
94hokies
Leave the harness in place in the car because I will need to use it for the conversion or just take it out and save it for safe keeping?
Old Jul 4, 2012 | 10:12 PM
Greatsteaks's Avatar
Greatsteaks
The vintage air system I installed in my wife's 1970 did not use ANY of the original wiring harness and I had to plug the vacuum line.
Old Jul 4, 2012 | 10:23 PM
shrekviper's Avatar
shrekviper
I did not use the original AC harness and since I replaced all the vacuum hoses, no plugging needed (just didn't put in the T).
MUCH easier to do w/ the motor out.
Old Jul 5, 2012 | 07:21 AM
wydglydrydr's Avatar
wydglydrydr
The VA system is going to tap into the fuse box and direct from the battery. It doesn't mate up to the original harness.
Old Jul 5, 2012 | 07:51 AM
Garys 68's Avatar
Garys 68
VA has their installation manuals online, check it out.
Old Jul 5, 2012 | 08:49 AM
oldalaskaman
excellent tech. I made the mistake of buying my aftermarket kit from another vender, but I didnt get the complete kit and used all of the oe controls. VA seems the best for the money.
Old Jul 6, 2012 | 04:56 AM
palmbeachvette76's Avatar
palmbeachvette76
Just installed a Vintage Air Gen IV in mine a month ago. Out with the old and in with the new, wiring was simple and straight forward, running the duct hoses is another fun filled story that ends with "I'd a sworn they wouldn't have fit but they did"
Old Jul 6, 2012 | 10:13 AM
94hokies's Avatar
94hokies
Thanks everyone. Looks like when I pull the engine this weekend, I can just pull that harness on out. New ignition harness is ordered and on the way too after I spent a day untaping the existing mess to see where all these new colored wires were running that were not on the diagram.
Since it will be past most of the DC summer here before I get things good enough to maybe put her on the road, I was planning on just doing all the AC removal stuff for now while it is all easy to access. Then get the engine/tko put back in and hopefully drivable. Over the winter and into next year put in Vintage Air, fix convertible top and prep for paint job.
Old Jul 6, 2012 | 10:22 AM
69firebird's Avatar
69firebird
Anyone know if the vintage air system will fit the later model C3's?
Old Jul 6, 2012 | 02:40 PM
opus1111's Avatar
opus1111
Good thread, good info- thanks! Going down this road myself soon, possibly.
Old Jul 6, 2012 | 03:50 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
before you fixate on vintage air, check out a classic air system if they have one available for your car. their products are specific to the year make and model they fit and usually use the same OEM switches, etc so from the cockpit it looks absolutely original. a friend just had his mechanic (and mine also) install a classic system in his 67 mustang coupe and the mechanic said he felt it was a better product than the vintage air system he had previously installed in a corvette grand sport daytona cpe replica he built for another customer. not a rep for either, just passing along another opinion.
Old Jul 6, 2012 | 04:03 PM
94hokies's Avatar
94hokies
Maybe both vendors will be at Carlisle or at least some resellers this year. I'll keep an eye out at the show for vendors and see what cars out in the field might have either system installed. If anyone here has one and will be there this year, would love to know and meet up. Hoping next year to be able to drive mine, only an hour trip or so.
Old Jul 6, 2012 | 07:22 PM
gkz's Avatar
gkz
Vintage supplies block off plugs, but you can glass them in for a smoother look.
Old Jul 7, 2012 | 08:49 AM
Rotonda's Avatar
Rotonda
Default Vinrage Air in a 77
I installed a Gen IV Vintage Air kit into my 77 (do a search for my write-up from earlier this year).
Later years (78-82) had both a different dash (Installation would require the loss of the glove compartment at a minimum) and a modern orifice system instead of the VIR system. For these I would recommend changing to 134a refrigerant, flushing the system, changing the orifice tube to a smaller diameter, replacing the compressor with a Sanden 508 and changing the condenser to a modern multipath one.
Old Jul 7, 2012 | 09:32 AM
Garys 68's Avatar
Garys 68
I've installed a perfect fit Vintage Air in my 68 corvette and a universal Classic Auto Air in a 72 442. The universal is verry similar to the vette kit.
Vintage Air is a couple hundred more but is a quite a bit more hi tech. The Classic Air is cable operated while VA has stepper motors to control the air doors. But then again, sometimes simple is better. The one downside of the Classic Air is that the defrost/heat/vent/AC control operates a single door that directs air between 2 sets of ducts, the defrost/heat and vent/AC ducts. So there is no separation possible between defrost and heat ports with their universal kit. Not a big deal to me since I'll most likely only use vent and AC. My only concern is if something fails in the VA, I'm pretty sure I'll be replacing the entire evaporator assembly.
Both companies were great to work with and substituted parts for my custom installs at no cost. Both cars were LSx swaps, so quite a few parts swaps were necessary. I think you're going to be happy with either.
Oh yeah the only problem with either was a stuck heater control vale on the VA system that became unstuck as soon as I removed it.
Old Jul 7, 2012 | 09:37 AM
oldalaskaman
excellent tech. on this thread, many thanks.
Old Jul 7, 2012 | 12:02 PM
69firebird's Avatar
69firebird
Originally Posted by Rotonda
Later years (78-82) had both a different dash (Installation would require the loss of the glove compartment at a minimum) and a modern orifice system instead of the VIR system. replacing the compressor with a Sanden 508 and changing the condenser to a modern multipath one.
So normally I would agree, however the PO bastardized the ac system in mine so I'll need to start from scratch, the box in engine bay is toast to, don't see a good way to redo the stock system, which made me
Think VA, maybe the universal will fit. I'll look into it more when the time comes
To Quick Vintage Air Questions
