th350 numbers??
Old Jul 7, 2012 | 05:50 PM
lowes-yellow77's Avatar
lowes-yellow77
Default for the hurst shifter guys
hey guys,
For you guys with the idea of doing the hurst shifter i found a part for the reverse lights instead of paying 100+ dollars for the stock brakcet and switch, here is the part # HUU-2480003, its a summit part number
Yep its me again, i think i spend more time searching the forum then working,
I have officially started the 4 speed swap and to the ones before me i applaud you im quite young and it took me 2 hours the pedals were a pita!! but i pulled auto trans today and was going to keep it if it was a matching numbers trans,has 4 bolt dust cover.
BIG ``K`` on top???
case--8640300= th350
pan--b7a129???
pump--gm44,,,6260233???
driver side--17S4a21052
no numbers on tailshaft or governer
any info would be great
thank you
mike
Old Jul 7, 2012 | 06:44 PM
'75's Avatar
'75
If this is your car serial no.-17S4a21052, then it's the original trans.
Old Jul 8, 2012 | 10:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by lowes-yellow77
...17S4a21052...
Your VIN derivitive should not have an alpha a in it. 17S421052 should also match the engine stamp. 21052 was assembled in January, 1977.
Old Jul 8, 2012 | 03:15 PM
lowes-yellow77
Default thanks
the car is built in early 77 i think in january, i know engine is not matching looks like i will hold on to trans in case someday IF i ever sell it and someone wants a auto i will have it
mike
To th350 numbers??
