Broken Shock.....
Old Jul 10, 2012 | 06:55 PM
Richard Cooper's Avatar
Richard Cooper
Default Broken Shock.....
Can a broken or bad shock cause the rear of my 81 to be an inch higher on one side? I noticed today that the drivers side is an inch higher then the passengers side in the rear. Can this be caused by a bad shock?
Old Jul 10, 2012 | 06:59 PM
The13Bats's Avatar
The13Bats
unless the shock was a coil over or air shock..um.....I dont see how...some brand new gas shock will lift a little but an inch?!?!?!?!
Old Jul 10, 2012 | 07:26 PM
heilman5's Avatar
heilman5
i noticed my 81 was a little higher on one side. i recently put new shocks and body mount bushings on. they made it more level.
Old Jul 10, 2012 | 08:34 PM
Richard Cooper
I am going to try new shocks, I have already replaced all the body mounts a few years ago. Thanks for the replys.
Old Jul 10, 2012 | 09:53 PM
my 76 ray's Avatar
my 76 ray
Measure the distance to the ground on both sides of the frame. If they're the same then the problem is with the body or mounts. If they're different then it's in the suspension unless the frame is bent.
Old Jul 10, 2012 | 10:38 PM
lowes-yellow77's Avatar
lowes-yellow77
Default mine was 3 inches higher
hey
I had the same problem with mine i adjusted the suspension in the rear. There are bolts with nuts and also i cotter pin if you loosen the nut down it brings the rear of the car down on that side and vice versa tighten it up and the suspension will go up. BUT you can only go so far down the cotter pin HAS to be installed still.
Also car must be on ground not jacked up. Its tight but very do-able
mike
Old Jul 11, 2012 | 07:42 AM
KevinG's Avatar
KevinG
Check to make sure that the front springs are seated into position correctly. I went from 1" off in the left rear to only 1/4" off after I fixed that.
Old Jul 11, 2012 | 04:54 PM
Richard Cooper
Thanks guys,
I will check my measurements, check my front springs and if all else fails I'll make the adjustment like Mike said.
To Broken Shock.....
