help with spare tire lock
Old Jul 11, 2012 | 11:27 PM
9492's Avatar
9492
Default help with spare tire lock
I can't get my spare tire lock to unlock. I have the correct key. It goes into the lock but will not turn to open. Any advice?
Old Jul 12, 2012 | 08:01 AM
BFI6603's Avatar
BFI6603
Have you tried lubing the cylinder with a little WD 40?
Old Jul 12, 2012 | 08:10 AM
Konkol1's Avatar
Konkol1
Are you sure you have the right key? The reason I ask is that I had some spare keys laying around and I wasn't sure if they were for the Corvette or my 87 Olds. The key would go into the cylinder, but would not turn. They were spares for my Cutlass.
Dale
Old Jul 12, 2012 | 09:10 AM
...Roger...'s Avatar
...Roger...
http://forums.corvetteforum.com/c3-g...tire-lock.html
Old Jul 12, 2012 | 11:48 AM
Jedi926's Avatar
Jedi926
Roger sent me the same tech advice and it worked awesome! Once I took off the whole assembly, I lubed the lock well and let it sit for awhile. Took me 30 mins but I was finally able to depress the pin and the lock assembly slid right off. Be patient, it will work. Good luck.
To help with spare tire lock
