77 Vette transmission help!
Old Jul 13, 2012 | 02:59 PM
texastyler642's Avatar
texastyler642
Default 77 Vette transmission help!
the manual shaft oil seal as i think its called is shot on my TH350 and it leaks trans fluid. ive got the pan off, the exterior bracket, and the filter off but i cant seem to remove the clip, the nut on the shaft on the other side of the shift comb and i also cannot remove the S pin. if anyone could help id appreciate it!
