flat tire today........
Old Jul 14, 2012 | 01:29 AM
ramair_bryan's Avatar
ramair_bryan
Default flat tire today........
Flat today on the way back from cruising the foot hill roads here in central cal. Thank god for flat fix in a can. .
100 degrees was hot out too. I don't carry the spare, cause I like the way the pipes look. But now......maybe I better think about that mini spare I have in the barn,.....and throw it in the back storage area.
One 20 0z can of fix made 20 psi.......and got me 30 miles back home. Then 3 hrs later I checked it......And it was flat. So don't waste any time when your moving. .
..Hot august nights coming up in reno. I better get ready. .....
Old Jul 14, 2012 | 03:40 AM
scottyp99's Avatar
scottyp99
I like having a spare tire, I guess I'm just old skool. A can of fix-a-flat is better than nothing, I guess, but I still like having a spare tire.
Keep the shiny side up!
Scott
Old Jul 14, 2012 | 07:43 AM
78pace's Avatar
78pace
In the 11 yrs I have owned the car I have never had the spare tire carrier down. I think it is the original tire from what I can see of it. I think it is time to drop it and put a new tire in there.........Don't want to steal the thread. But while we are on the subject what size tire are people using for a spare?
Old Jul 14, 2012 | 07:47 AM
U17's Avatar
U17
I did drop mine... It was useless!!! I pulled the carrier off and gave it away... Fix A Flat, compressor / jumper and AAA card...Living on the wild side !!!
Old Jul 14, 2012 | 09:22 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
I learned the from my family members who learned the hard way, you need to inspect your spare. My sisters had a flat and when they went to get the spare out, it was flat too. Hadn't been touched in years. I guess air slowly leaked out over time.
The incident inspired me to look at my spare. It was flat too. I think it had less than 15 PSI. Its a lessen to learn but can be avoided. REGULARLY check the pressure and usability of your spare.
Old Jul 14, 2012 | 09:27 AM
Lupigiato's Avatar
Lupigiato
Fix a flat does the trick short-term, but was told that the tire is useless after that and needs to be replaced. Something to do with how it seals the flat creates a lopsided mass on the wall and will be out of balance.
Old Jul 14, 2012 | 09:31 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Have you ever seen a wheel after using Fix a Flat?
Old Jul 14, 2012 | 10:05 AM
ramair_bryan
Running down to the local tire place at 7 59 am , to get it fixed, and have all the nails pulled out of the others. I remember when we were kids, we would do a burnout at night in front of our friends, and they would laugh because of all the sparks coming off the tires. .
Old Jul 14, 2012 | 10:34 AM
kdf1986's Avatar
kdf1986
I keep the spare tires on all my cars. I try to keep them stock looking and keeping the tire and carrier fits that build.
After reading this post though I think I will take the spare tire out of them to check the pressure. Might be something that I will try to do on one of my periodical checks.
kdf
Old Jul 14, 2012 | 10:37 AM
scrappy76's Avatar
scrappy76
This reminded me of when I bought my corvette. I was checking it out, laid down and looked underneath at the condition and also to see if it had a spare. well it did, so I thought. 2 weeks later started cleaning the underneath and lowered down the spare tire basket to clean more. Well it did have a spare tire, just no rim .
Old Jul 14, 2012 | 10:57 AM
ramair_bryan
Default no rim.........
Old Jul 14, 2012 | 11:10 AM
4SPDL81's Avatar
4SPDL81
St. Jude Donor '16
I check the spare tire air once a year...set the pressure to about 45psi...the next year when it is checked the tire has lost about 12 to 15 psi....
Old Jul 14, 2012 | 11:56 AM
rcread's Avatar
rcread
Last year on the way home from Napa, CA, in the middle of Nowhere, Oregon, we had a flat in my wife's Porsche. The sidewall was shredded and we had no cell coverage. This event convinced me to put the spare back on my '71.
Old Jul 14, 2012 | 12:11 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Wow, wouldn't that suck if you were driving along all confident, then BAM! Flat tire, no rim! DAAAAAAAAAAAMMMNNN!
Old Jul 14, 2012 | 05:31 PM
Vette5.5's Avatar
Vette5.5
You may consider installing a tire pressure monitoring(TPMS) system, as really not that expensive. C5 & C6 Corvettes have always had these, as use run flats, with no spare. All new cars 08' up, are required to have these now. While seems a bit much doing this, shred a difficult to replace tire, with a rare rim, and wish you had. I carry a Viair 90P compresser and plug kit in my car, even with TPMS.
Old Jul 14, 2012 | 05:36 PM
ShootCraps's Avatar
ShootCraps
I'm buying a can of Fix a Flat tomorrow.
Old Jul 14, 2012 | 07:07 PM
ramair_bryan
Dang.......................I shoulda bought stock in the company.......
Old Jul 15, 2012 | 04:38 PM
KTKelly's Avatar
KTKelly
Another nice modification to make?
Long line up to a air pressure gauge in the dash (maybe replace that silly non working clock)...
In my case, since I'm running a staggered set up, I'll have a 215/70R15 for a spare as the diameter in nearly the same as the 275/40R18's on the rear. I have a flat on the rear I can run the spare without damage to the posi. I have a flat on the front, I can have some really bad handling until the flat is fixed.
I have a flat with the wife along, I have a problem since I don't think I can put the flat behind the seats.
So is it: Strap her on the rear deck, or strap the tire on the rear deck?
To flat tire today........
