Jack Points on a 1979
Old Jul 26, 2012 | 06:18 PM
McVette's Avatar
McVette
Default Jack Points on a 1979
Help guys I am trying to change out my rims on my corvette and just wanted to make sure i jacked car up and placed jack stands in correct spot.......can someone help me out with some pics or links to some...Thanks
Old Jul 26, 2012 | 06:29 PM
junkman123's Avatar
junkman123
the way i jacked mine up was one side at a time.put the jack in the middle of the frame rail where the trans mount attaches. if you have to jack it very high remove the t-tops and open the doors so if there is any flex you wont crack or jam anything. any one else do it different?
Old Jul 26, 2012 | 06:40 PM
rcread's Avatar
rcread
You're probably changing out the whole wheel and not just the rims?
I jack the rear from under the differential and put the jack stands under the frame at the rear of the back edge of the door. I jack the front at the front edge of the door, on the frame, and put the jack stand in front of the hydraulic jack.
Old Jul 26, 2012 | 06:49 PM
McVette's Avatar
McVette
yea i purchased some rims and am going to take the wheels off myself and take to shop and have tires switched out on the rims
Old Jul 26, 2012 | 06:51 PM
McVette's Avatar
McVette
so u dont have to jack from right in front of the rear tire??.....asking cuz i dont know for sure
Old Jul 26, 2012 | 07:20 PM
briankeery's Avatar
briankeery
http://forums.corvetteforum.com/c6-c...locations.html
Check the first post
Old Jul 26, 2012 | 08:24 PM
junkman123's Avatar
junkman123
Originally Posted by briankeery
are the c6 and c3 points the same?
Old Jul 26, 2012 | 08:33 PM
McVette's Avatar
McVette
THX great pic
To Jack Points on a 1979
