1982 Restoration
Old Aug 16, 2012 | 06:46 AM
LS6 Motor's Avatar
LS6 Motor
Originally Posted by vette82forme
Mine will be for sale sine it is getting c4 suspension. Don't even think mine. Need rebuild. But could use bushings. Ide make you a good deal on them.
I might be interested, but I have to get these out first. If your getting rid of the drive line, do you have the cover for the Dana 44 in your 82? Mine has a crack in the cover.
Old Aug 16, 2012 | 11:04 AM
vette82forme's Avatar
vette82forme
Yes I have it condition unknown at this point though. It also has the composition spring and if all your suspension bolts rusted out I can tag and remove these as well
Old Aug 18, 2012 | 08:49 PM
LS6 Motor's Avatar
LS6 Motor
OK, day 49 of my restoration and here is where I'm at. Frame will be picked up on Monday by a friend at work to be sandblasted. I will have one small repair by the left kickup where the fuel lines had rusted in place along with replacing all the body mounts. I finally got the rear trailing arms out using a port-a-power. I lifted the trailing arms with a floor jack and slipped the jaws in the pocket under the arm until they finally pushed past the shim sets on each side of the bushing. As always, thanks to the guys I work with at Bob Johnson Chevrolet here in Rochester for loaning me a tool I don't have, or hand if I need it, in order to get me to this point. If I didn't work 50 or so hours a week, I think you could restore one of these in 10 to 12 months. Here is a couple pictures.
Old Aug 18, 2012 | 09:22 PM
vette82forme
I tried calling you but no answer
Old Aug 18, 2012 | 09:43 PM
alconk's Avatar
alconk
Do you plan keeping the motor stock or are you going to give it a few mods?
Old Aug 18, 2012 | 10:00 PM
vette82forme
How is your radiator support? That might be available from mine as well. I'm going to try and use my 90 vette cooling capsule setup in my 82.
My 82's is totally rust free as well.
Old Aug 23, 2012 | 07:25 PM
LS6 Motor's Avatar
LS6 Motor
No, I'm keeping it all stock. If I wanted a quick car I would have kept the 04 Z06 I had with 2500 miles on it. Once I rebuild the motor and go through the throttle bodies, this car should be reliable. I started taking the motor apart and the front crank seal was leaking along with the upper and lower intake manifold. Someone thought they could correct it with a couple of tubes of red silastic. No matter, I will put it back together the right way along with the fact that the gaskets are a lot better today.
