Dynamat Insulation
Old Aug 3, 2012 | 11:53 PM
TO_Vette's Avatar
TO_Vette
Default Dynamat Insulation
On another post there was a discussion regarding using Reflectix or Dynamat for under carpet insulation that was very useful that helped me choose Dynamat for keeping the heat and help keep the road noise down a bit.
I’m getting ready to purchase some Dynamat and trying to figure out how many square feet is required for a C3? Anybody know how much I might require?
Old Aug 4, 2012 | 07:47 AM
oldgto's Avatar
oldgto
I don`t know why the number 32 sticks out in my mind. I believe I read that same thread. I think 32 included the rear compartment and doors too.
Old Aug 4, 2012 | 08:11 AM
dembo's Avatar
dembo
I bought one extreme mega pack (9x24"x48") and was able to do the rear completely, the floors and tunnel completely, parts of the firewall and with leftovers I was able to do most of the doors. so no insulation on B-posts - halo.
Nick
Old Aug 4, 2012 | 09:21 AM
929nitro's Avatar
929nitro
I always thought Dynamat was for noise reduction and not really a good heat reducer?
Old Aug 4, 2012 | 09:57 AM
dembo's Avatar
dembo
it's 'heavy mass' so yes its for noise reduction. It also gives the impression of a more solid car when you shut the doors.
Nick
Old Aug 4, 2012 | 11:41 AM
TO_Vette's Avatar
TO_Vette
Found the Dynamat web site had a great pdf that helped with sizing. There they said that a c4 needed 36 sq. which is the same size of the extreme mega pack, figured that would work.
There have been a number of discussions on if dynamat helps with heat as well as noise.
Found a pdf on their web site that has specs that show it does both fairly well.
http://dynamat.com/download/vss/2657...y_Corvette.pdf
Thanks everyone.
Old Aug 4, 2012 | 12:02 PM
larryg3's Avatar
larryg3
TO_Vette,
thanks for the Post you just saved me a lot of time I am about to do the same and I also had the same questions about heat reduction and the amount of material. Good luck with your install.
Larry
Old Aug 4, 2012 | 12:37 PM
TO_Vette's Avatar
TO_Vette
BTW, the cost of the mega pack was much cheaper then on the pdf. I picked it up for $350.
Old Aug 4, 2012 | 01:06 PM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Where did you go to get it for 350? I'm about at that stage in my project.
Terry
Old Aug 4, 2012 | 01:40 PM
TO_Vette's Avatar
TO_Vette
Actually it was $328. I went to ebay and found a few sites all for around that amount and choose the one close to me. It was techronics.com located in Gardena Calif (www.techronics.com). I got 'DYNAMAT XTREAM 9 PIECES 24'' X 48'' for 328.15 plus $28 for shipping.
Good luck.
Old Aug 4, 2012 | 06:31 PM
oldgto's Avatar
oldgto
Eastwood carries a similar product that`s a little cheaper than Dynamat.
http://www.eastwood.com/eastwood-the...-material.html
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
Default another thought.....
I just did my 82 with Reflectix and am very pleased with the results. Much less expensive, bought one roll for around $35 and did the driver's and passenger side with some left over. Have not done the rear yet. I have to say that, it is a vast improvement with cabin heat reduction, it is non-exsistent. And that is also with the heater control valve adjusted and working properly.
We have had a very hot summer and I drive home in mid-afternoon in the height of the heat, and with the A/C running full blast constantly, it is very comfortable with the drive. There is no heat entering the cabin as before. Noise reduction, well that's another story, as I like hearing the sound of the engine and exhaust.
Again, just another thought........
Old Aug 4, 2012 | 10:49 PM
desue's Avatar
desue
I am doing this too...do you happen to have pics? How far up under dash did you go? I'm not taking dash out at this point. I don't care about noise reduction either, cars like this need to be heard!
Old Aug 4, 2012 | 11:41 PM
radiotexas's Avatar
radiotexas
I did not read the fine print for Dynamat. Got the entire car, every nook and cranny covered and then realized the Dynamat was for sound reduction. Yes, I know, and by the way, stupid only has one 't'. I ended up having to re-do the entire car ('70 big block ragtop) with a dedicated thermal barrier over the Dynamat. I did not use Dynamat's heat product simply because I found one with an advertising presentation that appealed to me. So now I have a car slathered with sound and heat reduction material. All in all, I'm not complaining. The car is mucho quieter and it knocked the dreaded big block oven factor down drastically.
If I could tap into the incredible resources of this forum...anyone know someone to rebuild a 454 water pump and increase the water flow? I don't want an after market pump, I want my original rebuilt.
Bonus points for rebuilder referral in the Houston area, but I don't mind shipping for a top notch job.
Old Aug 5, 2012 | 10:36 AM
oldalaskaman's Avatar
oldalaskaman
you can buy the dynomat 'hushmat' , 80 mils, a lot cheaper by the roll without the logo. bout $120 each for 20' rolls. 2 did my entire C4, fire wall to rear wall both doors and even under the healiner with two rolls and had extra. Made the a/c much colder and the car much quieter.
Old Aug 5, 2012 | 11:09 AM
HOOAH's Avatar
HOOAH
Just saw that and recieved the monthly advertisement mag yesterday where it's their featured product and on sale this month. They offer heat and sound barrier all in one. Pretty convicing video on their website too.
Terry
Old Aug 7, 2012 | 08:26 PM
74 LS4-454's Avatar
74 LS4-454
Don't mean to hijack this thread.....here is the info you requested.....
install starts at post #8. I still need to do the tunnel area and the rear, but as I stated, made a huge difference......no more hot feet or legs......
http://forums.corvetteforum.com/c3-g...e-answers.html
To Dynamat Insulation
