driver door
Old Aug 4, 2012 | 07:56 PM
Rudy80Vette's Avatar
Rudy80Vette
3rd Gear
Default driver door
Help!! My driver door wnot open key will move lock just a little to unlock and lock but will not release the latch is there a way to open the door so i can remove the pannel? passanger door works fine.
Old Aug 4, 2012 | 08:08 PM
PA14JIM's Avatar
PA14JIM
So I'm guessing the inner door lock **** isn't doing it either? If you can roll the window down and either use the AIM or a vendor's cataloge to see what the assy looks like to see which rod you need to be moving to unlock the latch. Maybe watch the pass door side to
see what isn't moving on the other door. I have on occasion been able to feed a rope lite into small spaces to light up the area. Jim
Old Aug 4, 2012 | 08:24 PM
Rudy80Vette
3rd Gear
Thank you Jim i'll check it out it seems to be binding on something but i cant see what it could be binding on it moves both lock and unlock but very little.
To driver door
