Hurst shifter knob
Old Aug 5, 2012 | 02:48 PM
Toke1's Avatar
Toke1
3rd Gear
Default Hurst shifter ****
Will a Hurst 4 speed shifter **** fit a 75 corvette. What is stock thread size. New to forum. Thanks
Old Aug 5, 2012 | 05:04 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
First, welcome to the forum.
Second, may I suggest decaf? If someone here on the CF knows the answer, tho you might not get one immediately, you needn't open more than one thread to find out.
That said, if someone would let me know the stock thread size (never bothered to mess around with any stock shifters), I've got a spare Hurst ball I could measure for comparison.
Old Aug 5, 2012 | 05:32 PM
TimAT's Avatar
TimAT
IIRC Hurst uses a 3/8-16 thread. The factory shift lever is a bunch bigger since it's got the reverse lockout junk running down thru it.
Old Aug 5, 2012 | 05:56 PM
TheSkunkWorks
I was afraid of that.
Of course, the real fix would be to shelve the PoS stock shifter altogether and install a complete Hurst Comp+ unit.
Old Aug 5, 2012 | 06:47 PM
Toke1's Avatar
Toke1
3rd Gear
Default Thanks
Been reading a lot of info on this forum, very usefull. Thanks
Old Aug 5, 2012 | 07:24 PM
lowes-yellow77's Avatar
lowes-yellow77
welcome
Alot of these guys have been working on these cars along time, pick there brain, they have some of the best knowledge ive ever seen for these cars.
if you wanna go hurst use these part numbers
shifter 391-5403
hurst linkage and install kit (summit) part number 3738611
hurst back up light switch .(summit)part number 2480003
your shifter handle is dependent on year.
Old Aug 5, 2012 | 11:58 PM
TimAT's Avatar
TimAT
The factory shifter mounts to the crossmember. They have been known to bind under high load situations. THe Hurst mounts solely to the trans and moves with the load. And if you want to appear original, some of the vendors have a factory lokk-alike stick that bolts to the Hurst shifter body.
Old Aug 6, 2012 | 06:32 AM
540 vette's Avatar
540 vette
I got a shifter **** made up b y these guys that looks just like a Hurst. And they will make it in any threads size. http://www.hotrodshiftknob.com/
To Hurst shifter knob
