Backfire
Old Aug 11, 2012 | 06:33 PM
vaughn007's Avatar
vaughn007
Default Backfire (PLEASE HELP!!)
Please help!!!
I just changed out a rocker arm because it was tapping and had some wear. (Before changing i adjusted it till it was quite but decided to check the rocker and push-rod for wear, rocker had some)
With the valve closed, i removed the rocker. I counted the turns for reference. Before installing the new rocker, i sprayed a bit of carb cleaner down the push in case the lifter was sticking a bit and let it sit over night. (i saw this idea here on forum)
I just finished putting the new rocker on and tightened one turn less than the removal, just till i could barely spin the push-rod.
I then put the rocker cover back on so i could warm the engine up before doing the final adjustment.
I tried to fire it up and it wouldn't run, just wanted to backfire through the carb!!! How is this possible? That engine ran perfectly the night before.
Did the carb cleaner screw up the lifter or possibly diluted the oil so it wasn't pumped up? How long should the engine have to be turned over to pump that lifter?
I can't understand that much backfiring from one oil-less lifter. I am lost on this one!
I would surely appreciate your feedback.
Thanks,
007.
Old Aug 11, 2012 | 07:02 PM
m and t's77's Avatar
m and t's77
Did you take any ignition wires off and not put them in the right order.Maybe you Need to do a compression test now and see which cylinder is the weakest.Also check you plugs maybe an electrode is now bent...
Old Aug 11, 2012 | 07:11 PM
vaughn007's Avatar
vaughn007
I didn't take any wires off. Just replaced the rocker. The adjustment should have been very close to being dead on.
Old Aug 11, 2012 | 07:13 PM
m and t's77
Take the cover back off and have someone spin the engine,see if it all works smoothly.
Old Aug 12, 2012 | 02:10 AM
vaughn007's Avatar
vaughn007
Found the problem!! The retainer bolt to lock the distributor in place some how came loose, wiggling the rocker cover off,i must have knocked the timing out of whack.
Thanks for all the help!
007
To Backfire
