Started the Dynamat Install
Old Aug 20, 2012 | 07:35 AM
MrJlr's Avatar
MrJlr
Default Started the Dynamat Install
After doing my new heater core install and a few other little things, I got started on the Dynamat...found it to be very easy - and very time consuming...!
I bought 2 boxes....might need a third - hope not but if I do - oh well.
I'm going to cover pretty much every surface that I can. So far the hardest part is laying upside down on my back over the waterfall....
It seems to me that really rolling the stuff on good and tight is going to give the best results....ya need good contact to dampen the vibrations.....
Just started.....
My $1.99 roller from Home Depot (Home paint dept)
Old Aug 20, 2012 | 11:57 AM
AirborneSilva's Avatar
AirborneSilva
Looks good so far, give us a report with your impression when your done
Old Aug 20, 2012 | 01:49 PM
jcloving's Avatar
jcloving
Are you going to use Reflectix or any other insulation? I recommend both a sound dampener and insulation for best results.
Old Aug 20, 2012 | 01:51 PM
MrJlr's Avatar
MrJlr
Yes....Reflectix over the Dynamat.....
Old Aug 20, 2012 | 01:59 PM
jcloving's Avatar
jcloving
Awesome. I did this mod in 2010. It made the cabin much, much more comfortable. Quieter too. I drove a friend's vette last night and there is a big difference between mine (quiet) and his (stock, noisy).
Old Aug 20, 2012 | 02:31 PM
MrJlr's Avatar
MrJlr
That's what I want to hear !!!
Old Aug 20, 2012 | 05:42 PM
oldgto's Avatar
oldgto
Did you do down inside the rear storage areas too? Looks like that would be the hardest areas to get.
Old Aug 20, 2012 | 06:09 PM
SIXFOOTER's Avatar
SIXFOOTER
Doing this on mine too and Yes the storage boxes are tough.
I put on Lizard Skin first
Old Aug 20, 2012 | 09:02 PM
Wuttin's Avatar
Wuttin
My install thread:
http://forums.corvetteforum.com/c3-g...e-at-last.html
Dynamat and Reflectix made an amazing difference in my 79...new stereo sounds incredible, car is smooth when cruising, big heat reduction. You'll like it.
Watch the edges...Dynamat gets real sharp and you tend to smooth it with your hand. Deep nasty cuts if you're not careful
Enjoy and take your time...well worth the effort,
Steve
Old Aug 20, 2012 | 09:50 PM
erikm12's Avatar
erikm12
Got a half of a seat to do yet then I'm pulling the carpet and starting my underlayment.
Any tips or helpful ideas you come across please share!
I didn't think of a roller....need one of those....
Old Aug 20, 2012 | 10:50 PM
brent319's Avatar
brent319
C3 of Year Winner (appearance mods) 2019
I used Second Skin and used a heat gun at times to soften it up, mostly in corners.
Old Aug 22, 2012 | 04:40 PM
StingrayLust's Avatar
StingrayLust
I used the exact same part when I did my sound deadening material. The plastic handle snapped after just a few passes so I ended up just using my fingers to grab the roller part. Yeah my knuckles got a beating this way, but felt I was able to get in tighter spots without the handle being there.
Old Aug 22, 2012 | 05:11 PM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
Default Me too
I sprayed the LizardSkin last weekend on everything, including the inside of the doorskins, then covered everything with Reflectix over that.
New Seatbelts and Carpet is going in this weekend.
Old Aug 22, 2012 | 05:23 PM
jcloving's Avatar
jcloving
These cars are much more fun to drive without the cabin heat problem. A couple months after I bought mine I was cruising at night with the T-tops out. About 80 deg. outside. On the way home my knees and calves started to sweat due to the heat. It was an oven.
Not so anymore. Much cooler and quieter. You guys will love your cars eve more when you are done. If you can pump in some ice cold air on top of that you will really be comfortable.
Old Aug 23, 2012 | 05:34 PM
moo2's Avatar
moo2
I've never drove mine yet. I'm still in the building stages. Do the interiors get that hot with the 350's or it this a big block thing?
Old Aug 23, 2012 | 07:51 PM
Shark Racer's Avatar
Shark Racer
All the cars... big blocks generate a bit more heat though.
Old Aug 23, 2012 | 08:17 PM
moo2's Avatar
moo2
Old Aug 24, 2012 | 09:44 AM
jcloving's Avatar
jcloving
I only have experience with the 350s but I imagine it is possible with the BBs too.
The fuel air mix is converted to energy. Some of that energy gets to the rear wheels but some is converted to heat. The SBC radiates that heat and it gets thru the firewall and tranny tunnel. I first saw this problem on my Dad's '72 Impala. In the heat of the summer that car was a bear to ride in. Radiant heat thru the firewall. Same problem in my vette until I did the hushmat/reflectix.
This fix was a major factor in making the car comfortable to drive. A/C was the other part.
To Started the Dynamat Install
