AC Compressor Voltage Low
Old Aug 25, 2012 | 09:40 PM
impalaman's Avatar
impalaman
Default AC Compressor Voltage Low
Got a quick question guys. The voltage at my compressor clutch is 10.8v
when the AC is on and the engine is at idle. Should it not be 12v ?
1978 L-82 with a 4-speed manual
Base idle when AC is not on: 900 rpm
Idle when AC is on: 700 rpm.
There is no AC solenoid as this is a manual trans car.
Thanks!
Old Aug 26, 2012 | 09:46 AM
SIXFOOTER's Avatar
SIXFOOTER
should be 12, or whatever the alternator is putting out. You might have some marginal connections through the circuit, open them up and clean them.
