What is this sensor?
Old Aug 26, 2012 | 06:01 PM
jdbuddy's Avatar
jdbuddy
Default What is this sensor?
I cannot figure out what this sensor is on my 79 with create 350. The wires have come off, but everything seems to be working. It is on the passenger side just above the starter.
Any help would be appreciated.
Old Aug 26, 2012 | 06:16 PM
oldalaskaman's Avatar
oldalaskaman
temp.
Old Aug 26, 2012 | 06:44 PM
GOLF72's Avatar
GOLF72
That is what I woud say too.
Old Aug 26, 2012 | 06:48 PM
jdbuddy's Avatar
jdbuddy
The temp gauge is working and there is another sending unit on the driver's side of the engine. It has a single prong and looks more like what is see for replacement temp units.
Old Aug 26, 2012 | 07:34 PM
oldalaskaman
you have ....'2'.... temp senders
Old Aug 26, 2012 | 08:07 PM
alswagg's Avatar
alswagg
That looks exactly like the sensor for electric fan on my 81. Exact same place also. triggered "on" at 210* off at 195*. At least that is where mine is regulated. Al
Old Aug 26, 2012 | 09:24 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Yep.
Was your 79 originally an L82 with air conditioning?
Old Aug 26, 2012 | 09:26 PM
jdbuddy's Avatar
jdbuddy
yes, I still have the A/C and it is working.
Old Aug 26, 2012 | 09:28 PM
jdbuddy's Avatar
jdbuddy
I did remove the valve that sends coolant to the heater core (installed a manual valve like a lot of people). Did that have a temp sensor?
Old Aug 26, 2012 | 09:50 PM
jdbuddy's Avatar
jdbuddy
Is this the reminance of an electric fan on the radiator?
It just turns freely now.
Old Aug 26, 2012 | 09:57 PM
oldalaskaman
lesse, yup there's a fan there
Old Aug 26, 2012 | 10:02 PM
jdbuddy's Avatar
jdbuddy
That must be it - temp sensor for the electric fan that was disabled when the new engine was dropped in. Car runs cool so I am not going to worry about it.
Thanks to everyone for the help.
Old Aug 26, 2012 | 11:55 PM
oldalaskaman
if your engine runs hot with the ac on , you may want to check into getting that system to work, it will make your a/c blow colder.
Old Aug 27, 2012 | 07:44 AM
Paul L's Avatar
Paul L
Old Aug 27, 2012 | 10:17 AM
jdbuddy's Avatar
jdbuddy
Thanks Paul, the diagram is a big help. I'll have the fan checked out to see if it still works and maybe plug the sensor back in.
Old Aug 27, 2012 | 10:45 AM
Paul L's Avatar
Paul L
That is from the 1979 Corvette GM Factory Service Manual. I sold my 1979 in 2003 but I at one point contemplated adding one. But it does not kick in until 238*F and my L-82 never came close to that temp so I did not go to the expense. I suppose a sensor with a lower temp kick-in could be found.
Old Aug 27, 2012 | 01:38 PM
jdbuddy's Avatar
jdbuddy
Yea, I recently put in headers (short ceramic coated) and even on the highway at 4k RPM I haven't seen my temp go over 225. I don't believe I need the electric fan, but it is a option that I will keep in mind.
Old Aug 27, 2012 | 02:40 PM
KapsSA's Avatar
KapsSA
The aux fan was on 79/80 L82/AC Vettes(along with the trap door in the bottom of the shroud).
ALL 81/82 got them but no trap door.
To What is this sensor?
