Radiator bracket rust?
Old Aug 26, 2012 | 08:38 PM
McVette's Avatar
McVette
Default Radiator bracket rust?
hey guys i noticed i had a small leak from under the radiator today and i noticed i got some rust issues from the radiator bracket ( not sure what it is called)...First off what are they called and who sells them.....I am planning on pulling motor out next month and would like to replace them then if possible, also just how much trouble are they to replace...please see pics ...Thank You in advance
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Aug 26, 2012 | 09:40 PM
George Ries's Avatar
George Ries
rad support they are bolted in so there not to bad to replace i did mine when my motor was out i got mine from corvette central it was 319 plus shipping and i also replaced the rad
Old Aug 27, 2012 | 01:41 AM
69 Convertible's Avatar
69 Convertible
who ever you get it from, make sure you save your old one to cross check it. I bought one from Ecklers and put it on. The shroud was off by half an inch. Couldn't figure out why it was off by that much. I/2 inch is alot on the vette. I finally took off the rradiator support and compared it with my old one. Found out that the bottom bracket was welded 1/2 off. Doing the shroud and the radiator was a big pain.
Old Aug 27, 2012 | 04:07 PM
McVette's Avatar
McVette
ok now I am afraid......very afraid...lol
Old Aug 27, 2012 | 04:54 PM
jcloving's Avatar
jcloving
How badly rusted is it? Evaporust will pull the rust out of the pits and leave clean metal. No, I don't work for them, but I do like their product.
I have cleaned many of my parts with it and simply prime and repaint. I usually degrease first and then dip it. Sometimes I have to use a steel brush to pull off the remaining paint.
Your call.
Old Aug 27, 2012 | 06:07 PM
McVette's Avatar
McVette
ohhh some of it like at the corner is rusted all the way thru...will have to be replaced i am sure
Old Aug 27, 2012 | 06:29 PM
loup68's Avatar
loup68
Army
Yes it really needs to be replaced. It is holding your radiator in the car. My company made them for 1960-1982 corvettes.
Old Aug 27, 2012 | 08:05 PM
McVette's Avatar
McVette
yeaa i am going to ...pulling motor out prob next month and will replace it then while it is out
Old Aug 28, 2012 | 08:12 PM
jcloving's Avatar
jcloving
Yes, too much rust. Replace.
Old Sep 21, 2012 | 08:54 PM
McVette's Avatar
McVette
hey guys is this bracket a single beam across the bottom or is it a complete frame surrounding the rad??
Old Sep 21, 2012 | 09:41 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Old Sep 21, 2012 | 09:50 PM
McVette's Avatar
McVette
thanks
Old Sep 22, 2012 | 12:26 PM
24695bob's Avatar
24695bob
Replace it...It honestly is not a difficult job IF you can turn a wrench...you are good to go..
Just about the only thing you an replace on a Corvette without doing the normal first step (of disassembling the entire car)
Some years had early production and late production designed radiators and supports so just make sure you order the correct design ..
Bob G.
Old Sep 22, 2012 | 03:34 PM
McVette's Avatar
McVette
thanks Bob I am gona pull the rad out and replace it...i wanted to clean up under the hood anywayzz...Thanks again
Old Sep 22, 2012 | 04:51 PM
AdamMeh's Avatar
AdamMeh
Vette salvage yard here in Phx. They have lots of rust free stuff and you won't have to worry about the aftermarketalmostfitsbutdoesntreallywork formycar problems.
Old Nov 22, 2012 | 09:32 AM
McVette's Avatar
McVette
could someone post me a link to 1 of these . or tell me what the official name it is called......getting ready to take advantage of holiday shipping and discounts but i want to make sure i got the correct 1?......1979 model, auto, L82 motor with AC not sure what other info might be needed?
Old Nov 22, 2012 | 09:55 AM
'75's Avatar
'75
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Old Nov 22, 2012 | 10:13 AM
McVette's Avatar
McVette
Thanks thats what I thought it was...Happy Turkey day
To Radiator bracket rust?
