--Customize YOUR Logo Light--
Old Aug 28, 2012 | 07:09 PM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
Default --Customize YOUR Logo Light--
I've caught up with alot of the custom stock stuff and now will be offering any custom image that you want. PM me your ideas...
Below are a few of the ones that I've done.
Old Sep 6, 2012 | 12:36 AM
Former Vendor
Old Sep 7, 2012 | 10:50 AM
jcloving's Avatar
jcloving
Andrew, where would these be used?
Old Sep 7, 2012 | 11:42 AM
Scottd's Avatar
Scottd
That is absolutely sick! (in a good way!!!!) I LOVE the ground projection. Whats an estimate on what these cost? Do they just run on a regular 12V source?
Old Sep 7, 2012 | 02:45 PM
Former Vendor
Generally used in the doors so that when you open them the image projects onto the ground but they can be used anywhere. I make a 9volt set up so you can actually carry it around with you. I also have a 360 + mount that you can set the light on and project onto walls or ceilings etc... and Lastly I have a wall plug design so you can plug it into your 110 powered houses and project it in your garage or even use it as a night light of sorts if you choose.
Old Sep 7, 2012 | 02:46 PM
Former Vendor
Appreciate it, are you referring to cost of a custom set? and you can run them on 12v hard wire, 9v or 110 with a special set up and plug I make.
Old Sep 11, 2012 | 08:28 AM
Former Vendor
More new custom lights for Customers
Old Sep 14, 2012 | 12:51 AM
Former Vendor
Old Sep 14, 2012 | 08:19 PM
Former Vendor
Forgot to add this one to the list
Old Oct 19, 2012 | 01:24 AM
Former Vendor
To --Customize YOUR Logo Light--
