First C3 wheel alighment
Old Aug 30, 2012 | 10:16 AM
ShootCraps's Avatar
ShootCraps
Default First C3 wheel alighment
Getting the wheels on my 75 aligned tomorrow at the Chevy dealer. Is there anything I should look out for, or bring to their attention with the C3's unique suspension? I was reading that camber on the rear wheels should be set to zero for street use. Is that right?
Old Aug 30, 2012 | 10:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ShootCraps
...Getting the wheels on my 75 aligned tomorrow at the Chevy dealer. Is there anything I should look out for...
No.
...or bring to their attention with the C3's unique suspension?...
No. They should know what they're doing.
...I was reading that camber on the rear wheels should be set to zero for street use. Is that right?...
No. My advice is to use the factory settings.
Old Aug 30, 2012 | 11:52 AM
rafalc's Avatar
rafalc
I have not done mine yet but others always tell me to take it to someone who is familiar with our old cars and knows what they are doing. This is a Chevy dealer but their 20-some year old mechanics may not have had any experience on C3s....
Old Aug 30, 2012 | 12:14 PM
MelWff's Avatar
MelWff
look at this link for alignment specs
http://www.vbandp.com/index.php?opti...man&Itemid=170
Old Aug 30, 2012 | 12:26 PM
ShootCraps's Avatar
ShootCraps
Thanks!
Old Aug 30, 2012 | 01:14 PM
ShootCraps's Avatar
ShootCraps
When I called to make the appointment he asked what kind of car and I said 1975 Corvette. He said hang on a minute and checked to make sure they could do it. I will be discussing it with them and watching. They are pretty flexible and did the same with my C5.
Old Aug 30, 2012 | 01:48 PM
Easy Mike's Avatar
Easy Mike
Things under your C5 are prettier than what's under your C3, but the basic adjustment process is essentially the same.
Old Aug 30, 2012 | 03:42 PM
76stingracer's Avatar
76stingracer
Take a copy with you and ask for the street numbers(or as close as possible). Ask for a print out of the final settings. Make sure the numbers are equal side to side. Right front caster should equal the Left front caster and so on.
To First C3 wheel alighment
