Drivers door operating mechanism
Old Aug 30, 2012 | 03:22 PM
gert4473's Avatar
gert4473
2nd Gear
Default Drivers door operating mechanism
The operating mechanism broke inside the door. I can't open the door from inside or outside. I can't take the door panel off because the door is shut. Any idea's on how to get to the mechanism to open the door. I think the only way is going to be destroying the panel. Hopefully someone will have another idea.
Old Aug 30, 2012 | 04:26 PM
mapman's Avatar
mapman
Welcome to the Forum!
First open the PASSENGER'S side door and remove that door panel.
Study the passenger's side lock as to how the lock/unlock mechanism works.
Practice opening the passenger's door lock by running a thin metal rod (with appropriate hooked end) into the lock through the door window gap.
This might show you what you have to manipulate in order to unlock the driver's side door.
Again, welcome to the Forum!
Old Aug 30, 2012 | 04:58 PM
gert4473's Avatar
gert4473
2nd Gear
Default drivers door operating mechanism
Good idea, thanks mapman I'll give it a shot.
Old Aug 30, 2012 | 05:03 PM
CQRT's Avatar
CQRT
If you have an assembly manual, check the detail . . but if memory serves, there's a horizontal rod that runs from the lock to the latch, and one that runs down from the door handle.
You should be able to hook that and lift it while applying pressure to push/pull the door open.
Good luck - -
Old Aug 30, 2012 | 09:07 PM
SIXFOOTER's Avatar
SIXFOOTER
When you get the panel off. Push down on the circled part. You Might be able to see it from above
Old Sep 1, 2012 | 12:11 AM
mark6669's Avatar
mark6669
I think you can remove all attaching hardware except lower screws at ends of panel and pull it off top of door to get to lever in sixfooter's post be careful and go slow and you may save the door panel I've done this once many years ago.Good luck.
Mark
To Drivers door operating mechanism
