Fuel Tank Replacement
Old Sep 8, 2012 | 06:16 PM
Al's Ride's Avatar
Al's Ride
4th Gear
Default Fuel Tank Replacement
Anybody have some tips on how to install a replacement gas tank on my '71? have had an extra set of hands as well as a floor jack, but it's still a challenge.
Old Sep 8, 2012 | 06:53 PM
grantstigers's Avatar
grantstigers
1. Jack the rear end and lift it at least 8 to 10 inches high or if you have a set of ramps tall ones. Jack the side of frame slide ramp under tire and do the same to the other side.
2. take off the tire carrier(makes things easier)
3 empty the tank
4. disconnect all hoses ie fuel lines, also up on the drivers side tank is a vapor valve bolted to the fuel tank, 2 hoses connect to it, try not to break the nut on the tower clamps. Not reproduced and cost lots if you can find them. The other fuel lines should be clamped together with spring clips.(may want to buy a repro set before you tackle the job. You may find you need new hoses and spring clips.
5. unbolt the lower bracket that holds the tank. Bolts are under the left and right frame.
6. Get your second set of hands to hold tank and lift one corner and then slide the other side out.
then it should come down and basically revers the method when installing.
Hope that helps. I just did my 71 but the body was off making it easier.
Grant
Old Sep 9, 2012 | 09:10 AM
Mooser's Avatar
Mooser
Get some longer bolts to help get the straps pulled down at the back. Once they are pulled down you can put the proper ones in
(Some have this issue, some don't)
Before you tighten everything up, check that the drain-tube from the filler isn't pinched
Make sure the bladder around the filler isn't jammed up in the filler door spring/hinge preventing it from closing all the way
HIH
Mooser
Old Sep 9, 2012 | 10:47 AM
Jeff_Keryk's Avatar
Jeff_Keryk
The biggest problem I had was a bolt on the exhaust hanger. Some exhaust shop with their air gun cross-threaded it in. Truth be told, this is an easy job. Oh yeah, the sender-unit cover that came with the new tank was too chinzy; I re-used the original.
Old Sep 9, 2012 | 11:04 AM
PRNDL's Avatar
PRNDL
This covers some (most?) of my job. If I can get through it, anyone can!
http://forums.corvetteforum.com/c3-g...tank-leak.html
hmmmm... that was 5 years ago and I guess I did ok... no fuel leaks or any related problems since.
To Fuel Tank Replacement
