rear reinforcement bracket..
Old Sep 14, 2012 | 08:45 PM
flaco1801's Avatar
flaco1801
Default rear reinforcement bracket..
I had the bracket laying around for a long time and had some time and tried to install it...Behind the bumper cover are 2 brackets attached to the frame to protect in a small rear end collision...One side was half a bracket and i wanted to replace it...I guess i tried awhile ago and gave up...Top bolt came out and the 2 underneath just kept spinning...I guess its some sort of bolt to prevent anyone from removing the protection...Has anyone ever replaced this reinforcement bracket???...Im thinking if i cant get the bolts off i can slice the bottom 2 bolt holes and slide the backet between the existing bolts and tighten them down...thanks, Jeff
