68 question
Old Sep 18, 2012 | 01:44 PM
gcwoodmancy's Avatar
gcwoodmancy
8th Gear
Default 68 question
New to Corvette forum!! I am a huge Corvette nut and i am looking at a 68, non-numbers matching (now has a 468, was orig a 427), auto, side pipes, new interior, ...basically, the car is great minus the orig motor. Question is, how much does the replacement motor reduce the value of the car?? Also has tons of work dont underneath... Guy is asking $17400 and i think it is a great deal. No rust at all anywhere and in great cond.
Old Sep 18, 2012 | 02:15 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
Some, but depends on the car. Your description of it sounds like a nice car, price seems good.
I think it's more of, How much would the original motor increase the value of the car? Which still may not be much, depending on varying factors with the car.
If you have done some homework, you will see pricing for small blocks a little less than big block cars, then factory options, then overall condition. History always helps, these are factors.
Old Sep 18, 2012 | 02:25 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Without pics, for the asking price the car ought to be the best 68 you've ever seen. Coupe or convertible? The sidepipes are not stock.
Good luck.
Old Sep 18, 2012 | 04:33 PM
gcwoodmancy
8th Gear
I see a lot of Vettes listed for sale and they are generally $20-26K. $17k seems pretty good.
Old Sep 18, 2012 | 05:03 PM
MelWff's Avatar
MelWff
perhaps too good? Do your homework before buying this!
Old Sep 18, 2012 | 05:13 PM
gcwoodmancy
8th Gear
What would you describe as homework?? As i am getting in deeper with purchasing cars, i am learning from Vette experts by asking questions. I would appreciate any red flags to look for...
Old Sep 18, 2012 | 05:24 PM
Scratch's Avatar
Scratch
Learning from those that own these cars, by just browsing threads is useful. Find info that pertains to your interest or 68 cars specifically. There is a thread on buying C3's somewhere here
So you know, 68 was it's own year, C3's that followed have different parts that do not inter-change.
Browse web sites that have these cars listed, look in the for sale section and see what is being described, pictures and info. That is the homework.
Where are you located, maybe a local member can help you out...remember, the search is part of the fun, as frustrating as it can be.
Old Sep 18, 2012 | 06:56 PM
BBCorv70's Avatar
BBCorv70
Generally speaking I hear the big block Corvettes are more sensitive to having numbers match than the small blocks. However you want to state it, a numbers matching big block brings more of a premium over a non numbers or a non numbers is a bigger deduction from a numbers car. The market has been soft. Without pictures nobody can offer much of an opinion on that particular car. If it's a convertible, from what I hear, that's about a $5K plus over a coupe. For a NOM (non original engine), I'd say $17K should be buying a car which needs nothing major like paint, interior, chrome, rust repair, etc. I'd guess it's getting near the top of the market for a NOM, impression I get from following similar threads related to numbers matching vs NOMs.
Old Sep 18, 2012 | 09:45 PM
uxojerry's Avatar
uxojerry
If the 68 is in great shape and your buying it to drive and have fun, it sounds like a decent deal. I would double check everything mechanical and electric to ensure there are no surprises.
Old Sep 18, 2012 | 09:58 PM
Rjplum's Avatar
Rjplum
Cruising
Be sure to inspect the frame really well. I would use a ice pick to check for weak spots. I learned the hard way on my 68.
Old Sep 18, 2012 | 10:07 PM
Stingray-Jer's Avatar
Stingray-Jer
Have you driven it? What has the car been used for? Check the FRAME. This is a must!
Is it a convertible? Check as much of the birdcage as possible. I just bought a 68 and it is not perfect. NOM engine. It has a 468. I am having to replace the clutch, flywheel, and go through the vacuum system. I also took the gas tank to the radiator shop and it it repaired. How is the rubber underneath the car?
Be prepared to spend some cash.
Old Sep 19, 2012 | 12:01 AM
vettebuyer6369's Avatar
vettebuyer6369
You still haven't said whether its a coupe or convertible. Its difficult to support the statement "$17k seems pretty good" when we don't even know that.
The cars that are "generally 20-26" (maybe 15-35) might not be remotely comparable to the car you have landed on. Help us compare apples to apples.
Is it the right color? What does the bodywork look like? Some people might deduct a bit for the automatic. How about options? A sharp, good condition roadster with an NOM big block "might" be pretty good if we knew more about the car. A mediocre no-option NOM coupe probably would not be pretty good.
There too much range here and not enough information.
Old Sep 19, 2012 | 09:27 AM
Easy Mike's Avatar
Easy Mike
...$17k seems pretty good...
It's your $17K.
Old Sep 19, 2012 | 04:32 PM
gcwoodmancy
8th Gear
You guys are awesome and i appreciate the responses. I drove the car today (coupe, not a conv) and it was 8/10. Looks like there are a few chips in the paint that need attention (the entire hood needs a repaint), but everything else seems great. The undercarriage was sandblasted and powdercoated. Looks great. Motor was blueprinted and balanced (no docs to prove the work was done...guy who did the work is old and does not like to detail the info on paper but has a great reputation in the area). Auto trans was rebuild as was the rear end.
I am also looking at a 73 454, auto, coupe, orig motor and just had a $8k paint job. 0 rust and is in Cali. Same asking price. I am leaning toward the 73.......
Old Sep 19, 2012 | 06:20 PM
Scratch's Avatar
Scratch
You have to set your sights on what type C3 you want. I wouldn't jump at the first one, compare that one, to others for what your money will get you.
Then again, you hate to see, the one that got away
To 68 question
