68 with & without air conditioning
Old Sep 18, 2012 | 08:02 PM
Luke in SA's Avatar
Luke in SA
Default 68 with & without air conditioning
Hi There,
I have a 68 SB that was originally fitted with air con.
The pump, hoses & radiator were removed many years ago by a previous owner.
I have no intention of putting air back into the car.
My question is -
What differences are there between air and no air cars ?
For example: Is there a different air con/heater box in the engine bay ?
Is there different vents in the dash panel ?
I would like to tidy the interior and engine bay over time. So i'm wondering what can and should be replaced to look like there was never any air.
Cheers, Luke.
Old Sep 18, 2012 | 08:24 PM
gbvette62's Avatar
gbvette62
Yes, the inner and outer heater boxes, as well as the heater cores itself, are different for AC and non AC cars. The non air outer box, will clean up the under hood area, and is basically a bolt in. Though you may have to do some slight firewall work, to use the non air boxes.
The vent in the top center of the gauge bezel, is not used in non air cars. There would be a panel that said "CORVETTE" on it, in place of the vent on non air cars. The duct work for the defroster and heater vents, are unique to non air cars too.
The shifter plate on non AC cars, has two rectangular slots cut in it, for the levers that control the fresh air vents. These slots do not exist, on AC car shift consoles.
The heater control is different on non AC cars too. The lens only says OFF-HEAT-DEFROST, and the non AC has different contacts and vacuum controls.
Old Sep 18, 2012 | 09:05 PM
vettebuyer6369's Avatar
vettebuyer6369
Like gb said, this is a typical non-air interior:
-note just above the gauge center cluster... on your air car you would have an adjustible air vent. There is a block off plate with "Corvette" on it.
-on the shift plate, you can see the 2 round ***** that go on the vent levers. (On a 68, I believe they are more squared/oblong). On an air car, the 2 long slots that the air vent levels travel down are not there. You would need an entire new shift plate.
Luke in SA's Avatar
Luke in SA
I have a new shift plate without the slots.
I have the vent cover plate with "Corvette" on it. (This was already fitted when I purchased the car)
I will need to find a non air heater box to tidy up the engine bay.
Do you know if a 69-70-71-72 are the same ??
I'm sure it will look much better as the current air box is huge.
Old Sep 18, 2012 | 09:08 PM
vettebuyer6369
Typical non-air shifter plate (with slots)
Old Sep 18, 2012 | 10:07 PM
DZRick's Avatar
DZRick
'68 non-air interior.
'68 only shifter plate.
Old Sep 18, 2012 | 10:08 PM
gbvette62's Avatar
gbvette62
Originally Posted by Luke in SA
I will need to find a non air heater box...
All 68-79 (air became standard in 80) non air heater boxes, are basically the same.
I would look for a 68-76 inner and outer box, as the controls are a little different, on the 77-79 heaters. The difference isn't enough that it would be difficult to overcome, but why make extra work for yourself?
Old Sep 18, 2012 | 10:53 PM
Luke in SA's Avatar
Luke in SA
Great help, Great forum.
Thanks guys.
Old Sep 19, 2012 | 06:48 AM
azza2u's Avatar
azza2u
Don't mean to be presumptuous but if you ever replace the wiper switch and a/c vent bezel with a non-a/c one I'd really be interested in it. Have been looking for a year an found lots of non a/c bezels but no intact and non broken a/c ones.
Azza
Old Sep 19, 2012 | 09:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Purchase the 68 assembly instruction manual and take a look at the diagrams for the optional factory AC installation. You can compare what the AC required with regular non-AC cars. There are aditional holes drilled in the cowl and the heater core hole was enlarged for AC cars. AIM shows how it was supposed to be cut. Driver's side fresh air vents are sealed. Console and center cluster changes you have already mentioned. HVAC controls in the console are (of course) also different and one year only.
My advice would be to keep the car factory AC and restore what's missing.
Old Sep 22, 2012 | 07:29 PM
Luke in SA's Avatar
Luke in SA
Azza
That wouldn't have been a problem, but.. My centre gauge bezel is broken in a few places. When I eventually get it all swapped over I will let you know what is good and what is not. Cheers, Luke.
Old Sep 22, 2012 | 08:43 PM
3JsVette's Avatar
3JsVette
If you're going to put everything back to "stock" this will not be easy or inexpensive no matter what direction you go. If you're going to spend money and time you might as well have a "factory air" car.
Now on the other hand if you're building a hot rod that's a different story.
To 68 with & without air conditioning
