Brake light dash warning
Old Sep 25, 2012 | 06:33 PM
Bob Dawson's Avatar
Bob Dawson
8th Gear
Default Brake light dash warning
I have a 1974 corvette and the brake warning light is on in the dash. What do I need to do to fix this problem. I have replaced the master cylinder, bled the lines. Anyone have a suggestion?
Old Sep 25, 2012 | 07:59 PM
Shark Racer's Avatar
Shark Racer
Did you put the ebrake down? Is the ebrake switch functioning? You should verify whether it's the parking brake or the prop valve switch causing it...
Old Sep 25, 2012 | 08:29 PM
C3 4ME's Avatar
C3 4ME
check for a leaking caliper.
Old Sep 25, 2012 | 08:34 PM
dar322's Avatar
dar322
St. Jude Donor '12-'13
just step on the brake pedal real fast and hard and it'll go away.
Old Sep 25, 2012 | 08:46 PM
U17's Avatar
U17
http://forums.corvetteforum.com/c3-t...-light-on.html
Old Sep 26, 2012 | 02:02 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
True, and it may come right back.
To Brake light dash warning
