Timing chain
Old Sep 27, 2012 | 04:02 PM
redwhitekat's Avatar
redwhitekat
Default Timing chain
My 74 has 82000 miles on it. Should I be getting ready to do a water pump and timing chain soon ? It's prob still the original
Old Sep 27, 2012 | 04:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Difficult to say. Both might be fine for a long time yet. You could also need either by tomorrow.
Is the water pump leaking? Making noise?
Old Sep 27, 2012 | 04:34 PM
redwhitekat
No everything is working good just wondering at what mileage or years do you guys change yours
Old Sep 27, 2012 | 05:01 PM
oldalaskaman's Avatar
oldalaskaman
if you have the time and dont use the car as a daily driver, changing those sooner than later will save things like tow bills, inexperienced mechanics , and being stuck places where you dont want to be. Its like with any other repair, 'while yer doin that, may as well do this too'. it helps for reliability and peace of mind. I sometimes buy the parts I plan on changing , put them on a shelf, and when its good for you , change them. if things break before you're ready, you already have the parts. hope this helps
Old Sep 27, 2012 | 05:10 PM
Tim H's Avatar
Tim H
if its the plastic tip gears its time, if its the steel gears probably not real urgent to change right now.
if you do change it get a Cloyes steel gears timing set and set it just like stock and then retime.
Old Sep 27, 2012 | 05:17 PM
Snoopysvet's Avatar
Snoopysvet
Advance it 4 degrees?
Old Sep 27, 2012 | 05:58 PM
imariver's Avatar
imariver
73, L48 with 108 K on the odometer.
Old Sep 27, 2012 | 06:19 PM
jb78L-82's Avatar
jb78L-82
I just did my timing chain on my 78 L-82 with 66,000 miles this past spring. The chain was slightly stretched and yes the cam gear did have the nylon gears like above^. All of my teeth were intact and the timing marks were straight up as they should be.
After much research and speaking in person with a couple of engine builders who told me that all the cams in the 70's came from the factory ground with a 4 degree retarded timing for emissions reasons, I purchased a comp cams double roller cam with an adjustable key so that i could advance the timing 4 degrees. I did install the new chain and advanced the cam 4 degrees and YES, it did wake up the motor. It feels more powerful, but i intend to get the car on the dyno in the next few weeks to verify any HP gain, if any, since i have a baseline run from last October when the engine produced 233 RWHP with the old chain.
Stay tuned!
Old Sep 27, 2012 | 06:42 PM
oldalaskaman
excellent tech many thanks
Old Sep 27, 2012 | 08:31 PM
Tim H's Avatar
Tim H
No, buy a cloyes and line up the dots.
Old Nov 15, 2021 | 07:06 PM
Jchapp's Avatar
Jchapp
Sorry wrong thread.
To Timing chain
