Terrible MPG
Old Sep 27, 2012 | 04:26 PM
Zennoth's Avatar
Zennoth
Default Terrible MPG
I just got a new engine in my 76 and it is a 355ci. It has a lot of horses but the gas mileage is seriously terrible. Like my 20-25 mile round trip from home to work sucks up 1/4 tank......This cant be for real right? If so i guess thats the price you pay for driving a classic. I love my car but that thing drinks gas like we breathe air!
Old Sep 27, 2012 | 04:34 PM
briankeery's Avatar
briankeery
What's engine rpm at highway speeds? At 70mph my tach shows 3500 rpm.I'm lucky to get 15 mpg on highway.
Old Sep 27, 2012 | 04:36 PM
Shark Racer's Avatar
Shark Racer
if you're idling the whole way or driving like Bondurant it may make sense... otherwise you've got an issue you need to chase.
Could be lots of things:
1. worn bearings
2. transmission issues
3. faulty ignition components
4. carb tune
etc.
If it's an auto with low gearing and no O/D I wouldn't be surprised to see 11-13 MPG on a city commute. This however only takes 2 gallons and shouldn't cause a 1/4 tank drop, more like an 1/8 at best.
Old Sep 27, 2012 | 04:37 PM
Zennoth's Avatar
Zennoth
I think it stays around 3000-3500 rpms. But i just feels like leaking gas....which i know i most definitly not, but i was just seeing if there was a tweak or part or something i could buy/modify to help a little bit in the gas devouring department
Old Sep 27, 2012 | 05:03 PM
Hogwild's Avatar
Hogwild
you need a overdrive tran 383 with 5 speed and 750 holley gets 20 to 25 at 1800 rpm .
typical white person
Old Sep 27, 2012 | 05:09 PM
Shark Racer
15mpg should still be consuming a lot less fuel than the OP is seeing.
Hogwild is right on the OD trans. A good carburetor tune is worth a lot of MPG too. There's really no reason to run richer than stoich @ cruise.
Old Sep 27, 2012 | 05:32 PM
gdh's Avatar
gdh
What carb are you using? Did you tune it using a wideband sensor?
Old Sep 27, 2012 | 05:38 PM
couperdecar's Avatar
couperdecar
Old Sep 27, 2012 | 05:54 PM
straitjacket's Avatar
straitjacket
how aggressively are you driving it? i rarely drive mine but when i do i tend to "wind it out" thru the gears just so i can hear that beautiful music my exhaust is making.
Old Sep 27, 2012 | 06:10 PM
Zennoth's Avatar
Zennoth
i drove it like an *** at first of course, but i have been driving very conservatively for the past week and it just suck that gas like crazy. My friend came out when it was running and goes "whew that thing smells like it is running rich" i dont know if thats the issue or if that is something that i can fix myself.
Old Sep 27, 2012 | 06:19 PM
Shark Racer
Need to know a lot more about the car before we advise you on how to fix...
Old Sep 27, 2012 | 06:31 PM
Zennoth's Avatar
Zennoth
what do you want to know
Old Sep 27, 2012 | 07:04 PM
Shark Racer
What kind of carb? What kind of trans? Do you know what rear gearing you have?
Old Sep 27, 2012 | 08:09 PM
scottw's Avatar
scottw
I'm running 15mpg with a zz4, th400 and 3.55 gears. That is 70% highways miles and not driving over 75 miles per hour.
Old Sep 27, 2012 | 08:52 PM
iokepakai's Avatar
iokepakai
Changed out the carb to a Summit 600 cfm,annular boosters one piece design.Cost was 239.00,ez to tune runs great no more fuel percolation,19-20mpg on the hiway running a 6spd OD trans.Before the swap I tried to rebuild the existing carb.Had similar issues as you are having now.Poor mpg,rich smelling exhaust,car would run ok but use a lot of fuel.Here's the writeup.http://forums.corvetteforum.com/c3-t...or-review.html
Demon has released a new street carb,looks like an modern Qjet
[IMG][/IMG]
If the Demon was out when I was looking for a new carb, I would've tried it.However the Summit carb is a great buy at almost 100.00 less!
Old Sep 28, 2012 | 12:35 AM
merc49's Avatar
merc49
might want to run smaller fuel lines.lol
Old Sep 28, 2012 | 07:37 AM
EmNash's Avatar
EmNash
In your other post you seem to be having issues with your vacuum lines. This, including the vac advance on your distributer will hurt mpgs.
To Terrible MPG
Old Sep 28, 2012 | 12:55 PM
KevinG's Avatar
KevinG
Got a 355 also. I'm lucky to get 13 mpg driving it easy with the occasional acceleration burst.
Old Sep 28, 2012 | 01:18 PM
Manuel Azevedo's Avatar
Manuel Azevedo
Don't believe what a fuel gage may show or not, how much fuel does it use in that 20/25 mile round trip? Saying a 1/4 tank by the gage means nothing.
Old Sep 28, 2012 | 01:57 PM
LastC3AZ's Avatar
LastC3AZ
If you're smelling fuel, you're probably running way rich ..... may be able to jet it down .... or you may have too much carb ...... what';s on it ????
whats your location ???
