Front crossmember replacement
Old Sep 28, 2012 | 10:31 AM
rafalc's Avatar
rafalc
Default Front crossmember replacement
The front crossmember has some rust damage and since I am replacing the radiator support, it just makes sense to do the crossmember as well.
Here is the question..... I have the car up on 4 blocks (the recommended jack stands areas). If I remove the front crossmember, is it safe to assume that the rest of the frame will not get out of alignment? I'm not sure how much of a role the front crossmember actually plays with keeping the overall frame structure straight and aligned. Or is it just for front weight support?
Old Sep 28, 2012 | 12:34 PM
mrvette's Avatar
mrvette
It unbolts and bolts up just fine, assuming the frame is in good shape....
Old Sep 28, 2012 | 02:22 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I've never seen a Corvette frame out of alignment unless it had been whacked. After you remove the radiator support, be very careful with the front clip. Don't put any weight on it because it will only be hanging there.
Old Sep 28, 2012 | 06:43 PM
72LS1Vette's Avatar
72LS1Vette
It's not safe to assume anything. You have to make sure that nothing is going to move when you remove and replace the crossmember.
Rick B.
Old Sep 29, 2012 | 02:09 PM
WESCH's Avatar
WESCH
Hi
When you loosen the 4 bolts holding it up, you will feel if the frame under stress or not.
Rgds. Günther
Old Sep 29, 2012 | 04:37 PM
68sbShark's Avatar
68sbShark
Originally Posted by WESCH
Hi
Rgds. Günther
Bolts on the front crossmember?
The center one, yes.
Old Oct 1, 2012 | 03:45 AM
WESCH's Avatar
WESCH
Hi
The very front one is bolted, at least on the early C3s.
This is then one forward of the radiator, I mean.
Not the one between the radiator and the engine.
Which one do we talk about ?
Rgds. Günther
Old Oct 1, 2012 | 11:23 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by 68sbShark
...Bolts on the front crossmember?...
Yep. The 68 in your avatar should have a bolted on front crossmember.
Old Oct 3, 2012 | 10:37 AM
rafalc's Avatar
rafalc
Thanks for the above answers.
From the pictures it looks like the new part already comes in painted black. Would you recommend I put an extra coat outside and inside to be safe or is it overkill?
Same for the radiator support.....
Old Oct 4, 2012 | 08:55 PM
nostgry's Avatar
nostgry
We are talking about the engine crossmember correct? Unless you have some add-on B.S. the only crossmember is the main engine crossmember. 1 question,... are you insane? Do you realize it's welded in? The strongest part of the car. It can be done. Pull the motor, all the suspension. Pay up the wazoo for the donor x-member. Thennnn you need a 220 welder, that is if you can hammer the donor into the correct place. Take a lot of measurements before you cut. Point to point. I have repaired cars and vettes for 39 years. I HAVE NEVER SEEN ANYONE CHANGE AN ENGINE CROSSMEMBER. My best advise if it is clearly gone,....... get another frame.
Old Oct 4, 2012 | 09:15 PM
rafalc's Avatar
rafalc
We are talking about this guy
https://www.paragoncorvette.com/p-35...ossmember.aspx
To Front crossmember replacement
