Which front bumper to use?
Old Sep 28, 2012 | 11:06 AM
mikekuhn's Avatar
mikekuhn
3rd Gear
Default Which front bumper to use?
I'm stripping my 1979 with urethane bumber that is wavy. What is the best type to replace it with?
Old Sep 28, 2012 | 11:24 AM
80Baby's Avatar
80Baby
Funny thing, this topic is coming up a lot lately. You've got three alternatives. Replace with O.E.M. It'll look great for years, but it will eventually distort. A fiberglass cover will stay rigid, however many guys blend the cover into front clip. Time consuming and costly because of the body work. Finally there's the Tru-Flex covers. They're flexible like the urethane covers but they don't distort over time. They install exactly the same as the O.E.M. covers.
As for cost of purchase, if memory serves me correctly the O.E.M. is the most expensive because it is of course "O.E.M." Followed by Tru-Flex, then the fiberglass cover.
I have Tru-Flex on my car. Not because I purchased them, they came with the car. Before I tore the car down I was impressed that both covers looked brand new. After pulling the covers off, that's when I discovered that they were not newer urethane parts.
Old Sep 28, 2012 | 01:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 80Baby
...Replace with O.E.M...
I agree, provided you can find an OEM bumper cover these days. Reproduction urethane is now available.
Truflex and hard fiberglass will require tweaking and fitting.
Old Sep 29, 2012 | 11:46 AM
24695bob's Avatar
24695bob
I own a 76 and 79.... and today they both sport Tru-flex front and back bumpers...
I replaced the front and rear of my 79 the first time with OEM bumpers and a few years later did the 76 with Tru-Flex .. 10 years after I installed the OEM ones on the 79 I replaced them also with Tru-Flex .. Paint faded and they were becoming wavy..
My 79 had the 78 Pace Car rear spoiler from the factory .. It is still on the car...but it is not only wavy ..the waves move with the sun ... noticeable at car shows when it is sitting out in the sun all day..
Bob G.
Old Sep 30, 2012 | 01:35 PM
LiveryStable's Avatar
LiveryStable
8th Gear
Tru-flex rear on my 79. Went with the 80-82 style with built in spoiler. Looks much better in my opinion but definitely took some time and effort sanding and shaping to make it fit correctly. Well worth the time and money in the end. Eventually I'm going to do the same with the front.
Old Sep 30, 2012 | 02:19 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
What do you guys mean by "shaping and fitting"? Are you buying these bumpers unpainted and sanding them down or what?
Thanks.
Old Sep 30, 2012 | 02:21 PM
LiveryStable
8th Gear
Thanks.
Yes, they come unpainted, usually in a black gel coat. You have to make the body lines match up correctly as well as the seam where it meets the body of the car. Takes some time and elbow grease but you'll be happy with it in the end.
Old Sep 30, 2012 | 04:22 PM
manofsteel1's Avatar
manofsteel1
He says "some elbow grease" well now....it takes a lot of work and fiberglassing. Never had a tru flex fit first time yet. Just take your time and just keep adding fiberglass. Some day you will have it built out to finally fit.
Old Sep 30, 2012 | 04:34 PM
sfrank2886's Avatar
sfrank2886
True Flex all the way. I mounted my own and when my body guy took over was not that bad. He did not even have to do any body work. If I do it again, I will be blending into the front.
Old Sep 30, 2012 | 04:39 PM
manofsteel1
You have any pictures for us all to see how it was done?
Old Oct 7, 2012 | 07:53 PM
Brians75's Avatar
Brians75
Cruising
Any updates on this? I just tried to fit a fiberglass (supposedly flexible per midamerica corvette) but I have a good 1" gap between the top of the bumper and the rear of the car.
It seems like the bumper itself is too big for the new part. I took off the bumper section near the license plate but there still isn't enough room.
I'm contimplating taking the whole bumper off.....not sure if it would pass inspection at that point.
To Which front bumper to use?
