Headlamp header bar
Old Sep 29, 2012 | 07:47 PM
MattCC81's Avatar
MattCC81
Default Headlamp header bar
I read the Wilcox how to install the header bar but I had some questions.
I bought the fixed headlights from ecklers. I removed the old pop ups to find out the header bar wasn't bonded it was just holding the lights together. Anyways I read about leaving the old bond on and just bonding it back. I figured I could sand the parts down and use the adhesive Wilcox used. Is that's all there is to it
Old Sep 29, 2012 | 09:16 PM
malicatasr's Avatar
malicatasr
I too am replacing the header bar on my 82. My origianl once unbloted came out real easy. I purchased a replacement headerbar from ecklers and plan on using the Sem panel adhesive. I had to purchase a special adhesive gun that mixes the two parts properly,
I actually have not dont the repair yet but plan on it next week. I will post pics of the progress. Good luck
Old Sep 29, 2012 | 09:34 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Hummmm You have the header out.. remove the old glue. If there are rivets buried under it remove them as well...
Then bond it back together per the instructions on our site.
Old Sep 29, 2012 | 10:06 PM
MattCC81's Avatar
MattCC81
Okay so just remove the old glue rough it up and clamp it.
Old Sep 29, 2012 | 10:12 PM
MattCC81's Avatar
MattCC81
Would you know how many 39747 panel adhesive I would need for the this
Old Sep 30, 2012 | 04:57 AM
malicatasr's Avatar
malicatasr
It looks like one 7oz tube should do the trick
Old Sep 30, 2012 | 07:45 AM
oldgto's Avatar
oldgto
I thought they discontinued the rivets in the later C3s? But if you have them, the Willcox method is the ONLY way to do it and have it come out right, at least it worked VERY well for me!
Old Sep 30, 2012 | 11:08 AM
mrvette's Avatar
mrvette
SO, it's possible to remove that header bar without pulling the entire front end apart?? I didn't think it was, my '72 has the usual swollen rivet problems and I just keep grinding them down when working on it, not the best solution, I know, so to grind off the rivets and then what??
Old Sep 30, 2012 | 11:09 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by MattCC81
...Is that's all there is to it...
It has to go back in exactly where it was when you took it out.
Oldgto: later cars do not have the rivets.
Old Sep 30, 2012 | 04:29 PM
0Willcox Corvette
Former Vendor
I wouldn't keep grinding on top Mrvette... that makes the fiberglass thinner and easier for the rivet to push up.
Putting the header in is a PITA but if you take your time anyone can do it. Removing any rivets is a must and 1 tube of the glue is all you need. If replacing just the metal then you'll need to leave some of the old bonding strip in there for spacing.
Here is the atricle I did on it:
Corvette Headlamp Header Bar Installation 1968-1982
To Headlamp header bar
