carpeted console side panels?
Old Sep 30, 2012 | 08:51 AM
jjpish68's Avatar
jjpish68
Default carpeted console side panels?
So how do you secure these? Mine keep falling out of place slipping down.
Old Sep 30, 2012 | 09:24 AM
oldalaskaman's Avatar
oldalaskaman
I reglued with the 3m product, then laced both sides together under the consol, used 80lb test halibut line, also put in two staples on each side, a little over kill, the line worked great
Old Sep 30, 2012 | 09:35 AM
jjpish68's Avatar
jjpish68
Thank You. I like that idea, I will have to give it a try.
Old Sep 30, 2012 | 09:37 AM
oldalaskaman
Old Sep 30, 2012 | 09:41 AM
qwank's Avatar
qwank
Mine are just held on with the 3 screws. the hard backing on the drivers side was warped and never fit right so I threw it out and just screwed in the carpet on that side. works fine.
Old Sep 30, 2012 | 10:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Trim screws and plastic inserts. The AIM shows how they mount and has a note about trapping the top edge of the panel under the console.
Old Sep 30, 2012 | 02:58 PM
Wrecked82's Avatar
Wrecked82
I replaced those with a molybolt when I had them off. Just loose enough to be able to move it to the correct location. Then replaced console side pannels with leather lined panels.
To carpeted console side panels?
