Hood Release Cable
Old Sep 30, 2012 | 02:22 PM
flaco1801's Avatar
flaco1801
Default Hood Release Cable
Yesterday i replaced the cable.Thought it was gonna be a snap...Read some posts and received some help from members...After removing the nut holding the cable i simply pulled out the cable,easy... When the cable is about 95 percent in it leaves the sheath and funnels into a rubber grommet...The grommet is cone shaped to receive the cable and flat where it enters the engine bay...It didnt mesh..I ended up pushing the grommet in and found it on the carpet...Now i was able to grab the cable and pull it out of the sheath and into position...i took the grommet out of the cabin and slid it over the new cable with the pointed side up and glued it back to prevent water from entering...Just wanted to post this for the next guy because i searched the forum to see if missed something..my car is a 74..a little help for the next guy...Jeff
