Improved Performance with 93 Octane - What Does This Mean?
I guess I didn't phrase the the sentence clearly enough, just assuming everyone knew Seafoam was a liquid, and would have understood the reference to "it"
The foaming action is what disperses it better throughout the top end, something the other brands don't do. even with pressure application.
Apparently you have never used the Mopar stuff and sounds like you don't want to. That is OK. I have used them ALL, WITH the pressure applicators, and without, in the gas tanks and direct and none come close to the Mopar stuff. Reread above, I said they all contain naptha, but the others contain additional solvents, probably why they also work better than Seafoam. And BTW, the Mopar stuff is cheaper than Seafoam.
As far as E10, this post was about probable top end carbon deposits, to which E10 contributes nothing. Rubber fuels lines and fuel delivery problems are a totally different issue.
No one dislikes E10 more than I, nor do I like using any additives or miracle cures, but trying to decoke an old engine that may have used leaded gas is well worth the process.
kits, which had adjustable nozzles, so you could tune the amount of water to your particular engine.
Mark
I do NOT however like any of the additives that go in the oil to cover up a problem like the honey stuff etc...but for somebody who drives a beater to work and can't afford to get it fixed it may be a bandaid to make a living. Thanks for the reply, sorry about the misunderstanding. Its all good!
Also, I would like to praise you and noonie for handling your little misunderstanding like grown-ups. Noonie calmly explained himself, and you graciously apologized for the misunderstanding, and it was over. See how easy life can be, everybody?
OP, this may sound sarcastic, but please don't take it that way. If you don't want to introduce anything into the intake to clean deposits from the combustion chamber, you are left with adding stuff to the fuel, which doesn't work well because of the dilution, and removing the heads and scraping the deposits off. Things like Seafoam and water injection are common operations which have been done many, many times over the years with good results, they are nothing to be afraid of, the only thing to be careful of is introducing too much product at once, which could result in hydrostatic lock. You would have to introduce the material at quite a high rate for this to become a concern, though.
Keep the shiny side up!
Scott
@ScottyP - not sarcastic at all! Admittedly, I've always been of the mind that nothing but gas and air should get past the carb - especially water. That said, this was based on limited knowledge (which is curable with an open mind).
Clearly, there are well-established practices and products meant for cleaning the top end. Looking back, I would've loved to have known about this with a couple of motorcycles!
At any rate, I'm looking forward to trying this process to see what kind of improvement it gives! With all of the reported smoke, I just have to remember to make sure the @$$ end of my vette is pointed outside!
Scott
