Adjusting/fitting window on a 1978
Old Oct 5, 2012 | 08:33 AM
Doug3X2's Avatar
Doug3X2
3rd Gear
Default Adjusting/fitting window on a 1978
Mt '78 has not been hit and the doors and tops are as they came from the factory.
When the window is up, the glass closest to the door is too far from the weatherstrip, i.e. it leaks wind and water.
The Service Manual (page 2D-9) says to "Loosen bolts (D,E). Back off adjusting screws (G)." Fig. 2D-16 does not identify adjusting screw G. I can not locate an unidentified adjusting screw anywhere.
Anyone have an idea where adjusting screw (G) is located?
FYI - The adjusting procedure in the Assembly Manual (page 241 and 242) is an entirely different procedure and appears to be a start from scratch procedure.
