engine
Old Oct 10, 2012 | 08:22 PM
scrappy76's Avatar
scrappy76
Originally Posted by Doug Kraft
Did the same 30 years ago. Get the right rad shroud, pulleys, headers and drop it in. I used the stock rad, springs and the bellhousing that came with the car, although I did put a new clutch on it. My motor had the balencer and flywheel already on it when I got it. When we were ready to set it in from the time I stopped the org 350 after driving over to my friends shop untill I started the big block it took alittle over 4 hours. Hardest part was driving back home thru town with the open headers. So if you ask me it really isn't a "big deal"
by myself, I pulled my 350 out on friday and dropped the 454 in on saturday. had it running on sunday. used original springs and radiator. added taurus electric fan, pulleys and brackets. also added headers and sidepipes. I would say each day I spent about 5 hours. Motor is stock and I am not racing it, so leaving the th350 tranny and stock u joints.
Old Oct 10, 2012 | 08:37 PM
Doug Kraft's Avatar
Doug Kraft
You won't even need a taller hood if you use a low profile stock intake that is set up for a Qjet. You could even then use an adapt plate and put a holley with a drop base air cleaner on it. No painting necessary unless you want to. I know that the trend is to put a newer engine or beef up the small block but IMO nothing beats the look on some peoples faces when you open the hood and they see nothing but motor!
