Glove Box
Old Oct 7, 2012 | 10:34 PM
TO_Vette's Avatar
TO_Vette
Default Glove Box
On my C3 I'm trying to get the glove box cover off and can't see how to get the lock off? How do you get that off?
Any ideas how to get this lock off the glove box?
Old Oct 11, 2012 | 02:44 PM
TO_Vette's Avatar
TO_Vette
Anybody know how to do this?
Old Oct 11, 2012 | 03:01 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Don't quote me on this (it's been ages since I did it), but I think you remove the lock cylinder in order to get to the retainer.
I won't be able to check the AIM until this evening.
Old Oct 11, 2012 | 03:03 PM
TO_Vette's Avatar
TO_Vette
I agree but how do I get the cylinder off.
Old Oct 11, 2012 | 04:26 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Don't have my '78 AIM handy at the moment, and haven't had cause to study up on this particular item, but might there be a retainer clip behind the ****?
Old Oct 11, 2012 | 06:34 PM
Mooser's Avatar
Mooser
Bear with me this could be wrong (been a loooooog time)
Open the door and trip the latch (as if it was closed)
put the key in and lock the cylinder (don't turn it the other way and open it)
There should be a small little opening on the side of the latch right down by the inside of the door, opposite side from what you have pictured above, bend a paperclip or use a small flat screwdriver or allen key and if you press in there it should release the lock cylinder out the front
Looking at your picture again the slot might be right under the fork that hands out rather than on the side where the older ones were
HIH
Mooser
Old Oct 11, 2012 | 06:42 PM
Shark Racer's Avatar
Shark Racer
On the front side, pop the chrome guide off (it's just a press fit) and then there'll be a retaining ring behind it. You can loosen the retaining ring and pull the cylinder out that way as well.
Old Oct 11, 2012 | 11:03 PM
TO_Vette's Avatar
TO_Vette
Default Still not there
So I popped the chrome guide off and I see this nasty thing that looks like it was once a screw but no retaining ring. Can't beleave that someone did that much damage to screw putting it in.
Wanted to see if anybody had been down this path. Do I drill out this screw and will that get this lock out?
Old Oct 12, 2012 | 11:45 PM
TO_Vette's Avatar
TO_Vette
any input would be welcome before I break out the drill.
Old Oct 13, 2012 | 12:11 AM
bluthundr's Avatar
bluthundr
Try slotting the top with a small dremel cutoff wheel and a flathead screwdriver before drilling it out.
Old Oct 13, 2012 | 02:17 AM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
My '79s once just fell out. There was a "nut" that went around the entire cylinder from the inside of the glove box if i remember right. What year exactly is yours?
To Glove Box
