C3 headlight cover adjustment
Old Oct 9, 2012 | 05:12 AM
cue487023's Avatar
cue487023
Default C3 headlight cover adjustment
Hi All,
Can anyone tell me where to find some info on adjusting the alignment of the headlight covers so when they are in the closed position the gap is even around the body (hope this makes sense).
Thanks, Colin
Old Oct 9, 2012 | 05:20 AM
gcusmano74's Avatar
gcusmano74
The hinge bearings are slightly movable, if you loosen the bolts that mount them to the body. Push 'em around till you like it, and then retighten.
Old Oct 9, 2012 | 08:30 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by cue487023
...Can anyone tell me where to find some info on adjusting the alignment of the headlight covers so when they are in the closed position the gap is even around the body...
Chassis Service Manual. Willcox might have a tech guide on their site.
Old Oct 9, 2012 | 08:08 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Got a video now Mike...
The pivot spacers control left to right, the stops control the upward and downward and you'll bet a little movement out of the side pivot bolts...
Old Oct 10, 2012 | 06:59 AM
cue487023's Avatar
cue487023
Awesome. Thanks for the video. Think this will save some reading time!
Old Oct 12, 2012 | 06:46 PM
0Willcox Corvette
Former Vendor
No problem.. I have 40+ video's that have been shot.. there just isn't enough time in the day to get them all up sometimes.
Old Oct 14, 2012 | 01:12 PM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
Default question?
Ernie, great video. When you adjust the clevis, should the headlight door be opened or closed? thanks....Tom
Old Oct 14, 2012 | 02:38 PM
74 LS4-454's Avatar
74 LS4-454
think I found the answer in the service manual, if I am reading correctly, the headlight door is in the up position with the engine running for vacuum......will try it....
Old Oct 19, 2012 | 12:07 PM
TWINRAY's Avatar
TWINRAY
That video is the bomb . Thanks
To C3 headlight cover adjustment
