Ping Easy Mike?
Old Oct 16, 2012 | 12:49 PM
Clams Canino's Avatar
Clams Canino
Default Ping Easy Mike?
Hiya!
You got a part number and applicable uses for a water pump pully?
1968 - 327 - no PS, no PB, no AC.
Outta have 2 rows I believe.
Not sure if the 300 and 350hp used the same one - I can't see a reason they would not?
-W
Old Oct 16, 2012 | 12:52 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
AIM probably shows it and the part number.
Old Oct 16, 2012 | 01:37 PM
Clams Canino
The AIM shows:
Non AC 3890419
With AC 3876846
But it doesn't show what other years had the non-ac pulley part number?
It also shows a 3941116 belt on the 2nd track - running just from the crank to the waterpump - with no way to tension it? Is that correct? (must be I guess)
-W
Last edited by Clams Canino; Oct 16, 2012 at 02:00 PM. Reason: Fixed typo in part number.
To Ping Easy Mike?
