1969 Interior mirror?
Old Oct 17, 2012 | 01:13 AM
vettebuyer6369's Avatar
vettebuyer6369
Default 1969 Interior mirror?
I noticed the "new" repro inside mirror I bought for the '69 is drooping and won't stay in place... this is a replacement of another one I bought that actually came apart in my hand when I adjusted it while driving.
Sources will remain unnamed.
Anyone have any luck on this part? I see ZIP and Paragon both list a "reproduction" and a "replacement" with the repro about $25 more. Not interested in price. Anyone have recommendation on the right part?
Old Oct 17, 2012 | 08:45 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
No way to tighten it? I have to do that from time to time.
If I'm looking for a replacement part I always go to Paragon or Dr Rebuild first....you might want to call them to discuss.
Old Oct 17, 2012 | 09:09 AM
gbvette62's Avatar
gbvette62
Is the mirror "drooping" where it attaches to the "ball", or where it attaches to the windshield header?
If it's at the ball, is the little square spring steel insert, in the hole on the mirror's attaching stem? If that square insert is missing, the mirror will droop.
If the problem is at the header, it could be the mirror bracket on the header, the retaining clip, or both. The curved arm with the ball on the end, that the mirror attaches too, has another ball at the header end. The upper ball is held into the mirror header bracket, by a "U" shaped steel clip. These clips are spring steel and can loose their tension, or even break, allowing the mirror droop. Also, the header bracket has 2 little loops cast into it, that the mirror clip is held up by. If one of the loops breaks, the clip cannot keep tension on the mirror support ball, also allowing a mirror to droop.
I can't take any pictures right now, but if I can I'll post some a little later.
To 1969 Interior mirror?
