The actual bumper will be attached to the chassis prior to the drop. The cover (74) has no honeycomb material like the picture so I'm not 100% sure it will fit with the 74 "cover" attached.
I can figure it out. LOL I was just being lazy and thought I'd try here first.
Thanks for taking the time to post the picture.
Front and rear bumper covers need to be removed to drop the body straight on. Get a couple of pieces of 1/4" pipe, maybe 18 inches long each, to use as drop guides. Open each door, and remove the sill plates. You will see two plastic plugs on each side. Carefully remove them. One hole on each side will line up with holes drilled in the frame. Use the pipes as guide pins in those holes when you reinstall the body.
Good luck.
