Sidepipes.... Stainless or black?
Old Oct 20, 2012 | 02:52 PM
mn_leaf_fan's Avatar
mn_leaf_fan
Default Sidepipes.... Stainless or black?
Thinking about adding sidepipes to my '75.
I don't know what would look better with black paint and Vector wheels... stainless, black, or black with a stainless shield?
Opinions?
Old Oct 20, 2012 | 03:20 PM
demoke's Avatar
demoke
Stainless...you may not be able to see the black ones.
Old Oct 20, 2012 | 03:27 PM
U17's Avatar
U17
Kinda biased....
Old Oct 20, 2012 | 06:27 PM
straitjacket's Avatar
straitjacket
i would go stainless. you got a lotta black on that car. black body , black wheels. need to throw a little bling, bling on it.
Old Oct 20, 2012 | 07:44 PM
mn_leaf_fan
Thanks for the feedback.
Most of the pics of Vettes I've seen 'on the net' the side pipes more or less match the wheels. Bright wheels = bright pipes. I thought the stainless side pipes might look out of place.
Old Oct 20, 2012 | 08:38 PM
Ironcross's Avatar
Ironcross
STAINLESS........
Old Oct 20, 2012 | 08:45 PM
texasbaehr's Avatar
texasbaehr
I put factory style side pipes with fiberglass covers and painted them satin black.
Old Oct 20, 2012 | 08:55 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I'd go with 1) black headers (complete) and blacked-out rocker trim, or 2) stainless with bright rocker trim. Wouldn't mix black pipes with bright rocker trim.
Old Oct 21, 2012 | 09:16 AM
optiman's Avatar
optiman
SS all the way
I want those vector wheels, have been looking for a good deal on a set.
Old Oct 21, 2012 | 10:25 AM
Phil Zell's Avatar
Phil Zell
You decide.
Old Oct 21, 2012 | 10:34 AM
palmbeachvette76's Avatar
palmbeachvette76
Stainless
Old Oct 21, 2012 | 08:02 PM
3JsVette's Avatar
3JsVette
Stainless!
Old Oct 21, 2012 | 09:02 PM
keithinspace's Avatar
keithinspace
I'm a little different than everyone else. I currently have chrome (rusty chrome, but chrome) sidepipes that are due to be replaced. I also have a black car, albeit with standard rally rims.
I have the chrome SteelShields.
I'm actually going with black pipes and 'setting them off' with the chrome SteelShields. My car is going to stay in the 'Road Race L88' side of the fence, so I'm going with a little more of a functional/racing look than the full chrome/show look.
If you plan on getting SteelShields (which I highly recommend), I'd suggest the black pipes on your car. If you DON'T get the shields, I'd do stainless.
Old Oct 22, 2012 | 12:38 AM
SuperBuickGuy's Avatar
SuperBuickGuy
Grey
Old Oct 22, 2012 | 03:10 AM
Bangkok Dean's Avatar
Bangkok Dean
The Steelshields could be painted hi temp black if you sandblast them so the paint will hold.
BTW, Steelshields are highly polished stainless steel not chrome plated that could peel or rust.
Here is an example of what they look like on black side pipes.
Old Oct 22, 2012 | 09:39 AM
keithinspace
Originally Posted by Bangkok Dean
...Steelshields are highly polished stainless steel not chrome plated...
My apologies. You are correct. I was using the term "chrome" in a generic manner to mean "really shiny". But they are a very durable polished stainless.
Old Oct 22, 2012 | 10:15 AM
mn_leaf_fan
Great looking options. Thanks for all your opinions.
Whether black, 'shiny', or grey it seems everyone tries to make the sidepipes compliment the wheels.
I like my Vector wheels as they are ( although they need to be freshened up ), but would consider painting, or polishing them to better match whatever sidepipe option I go with.
I like the black pipes with stainless shields or all stainless with my wheels as they are.
Grey or silver pipes with matching paint on the wheels could look good too.
Tough choices.
The only thing I know for sure, is that with sidepipes, I will either have heat shields or fiberglass '69 covers. I don't want anyone getting burned.
To Sidepipes.... Stainless or black?
Old Oct 22, 2012 | 10:22 AM
SuperBuickGuy
I measured the temps with my sidepipes. I measured them without any insert, with a spiral insert, and with the reverse-flow hookers (that are in them now)....
With nothing - ~ 600*
with spiral - 367*
with RF - 167*
I've hit them (with my ankle) while wearing shorts on in the last situation - I didn't get burned - of course, your mileage may vary; but while they can be very hot, with muffler inserts the need for a cover becomes optional.
Old Oct 22, 2012 | 10:32 AM
keithinspace
Bear in mind that the 4" Hookers are the "performance" option out of the two since they are large diameter long-tube headers into a sewer pipe of an exhaust. And that this option is not compatible with the '69 covers.
The "factory" sidepipes leave a cast-iron manifold and uses a single pipe the whole way back. I guess there are some options here with 'shorty' headers, but this option would generally have a little bit more backpressure baggage with it. Although, it is more 'correct' than the Hooker route.
My limited understanding is that the Reverse Flow inserts are quietest, but are considerably more restrictive than the more 'open' options. That actually makes sense with Mr. SuperBuickGuy's informative measurements. The longer the exhaust gasses are "in transit" and interacting with obstructions, the cooler they are. Some folks, expecially with Big Block cars, have identified a marked DECREASE in performance with these particular inserts.
Old Oct 22, 2012 | 10:42 AM
SuperBuickGuy
yep, there is a performance decrease, until you tune for the new mufflers (and then there is still one, but a lot smaller)
I agree with all you said, this also helps - there is a 3/8" sealed airspace around the reverse flow mufflers - which means that the max flows would probably have the same kind of temperature decreases.
