Red LT-1 Hood Question
Old Oct 21, 2012 | 10:55 AM
rehirsch8's Avatar
rehirsch8
Default Red LT-1 Hood Question
I just took my red '72 convertible to the shop to have the hood repaired because the heat from the air cleaner is cracking the paint on my base model hood. The previous owner restored the car with a 1970 four bolt main small block and 1968 heads, Edelbrock manifold and Holley carb. I'm thinking of changing the hood to a LT-1 hood to get more clearance and I like the look since it is no longer a numbers matching car. Was the pin striping on the red LT-1s always white from the factory? I've seen pictures of numbers matching cars with both white stripes and sometimes black stripes. My convertible top is white so I think it would look good with the white stripes and decal. I'm not trying to trick anyone that it's an LT-1 but I like the look and need the clearance.
Old Oct 21, 2012 | 11:03 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Technically, since the hood will not be original, you could choose the color of the stripe you want.
The NCRS Judging Guide says silver, white, yellow, and orange cars got black stripes.
All other colors got white stripes.
Not sure what's going on with your hood, but there should never be enough heat underhood heat to cause paint problems.
Old Oct 21, 2012 | 01:50 PM
Gordonm's Avatar
Gordonm
When I had mine painted I had the original red color wit hblack pinstripes and a white top. It looked great. I always thought the white strip kind of got lost on a red car. I have many pictures of the hood if you would like to see them. I now have an L88 hood with black on it also. I am going to switch to a black canvas top also.
Old Oct 21, 2012 | 02:34 PM
rehirsch8's Avatar
rehirsch8
I'd really like to see some of those pictures. While the white stripes would match my roof I'm not sure I care for the white stripes on red as much.
Old Oct 21, 2012 | 02:36 PM
rehirsch8's Avatar
rehirsch8
Thanks, this is very helpful.
Old Oct 21, 2012 | 07:18 PM
Lupigiato's Avatar
Lupigiato
I have a modified 327 in my 68 with Edelbrock heads, Holly 750 carb, Comp Cams, etc and do not have any paint issues on my hood - certainly nothing heat related. I too want to go to an LT-1 hood for space as it is a little tight in there.
Old Oct 21, 2012 | 07:51 PM
rehirsch8's Avatar
rehirsch8
Wow, very nice! The paint on mine is about 15 years old and just started cracking recently.
Old Oct 21, 2012 | 08:32 PM
Gordonm's Avatar
Gordonm
The pictures are in your email
Old Oct 22, 2012 | 10:14 AM
nelson007's Avatar
nelson007
Hello All,
Are the pin stripes painted or are they a decal?
Nelson007
Old Oct 22, 2012 | 10:46 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by nelson007
...Are the pin stripes painted or are they a decal?...
Factory stripes were painted using a stencil.
To Red LT-1 Hood Question
