goodyear eagle tires
Old Oct 22, 2012 | 05:37 PM
STL 71 C3's Avatar
STL 71 C3
Default goodyear eagle tires
Anyone here know how to date some Goodyear tires?
Check out this tire, there is a dip in the sidewall toward the tread. This one is worse than the others, is it normal?
There is a ton of tread on these tires so I hate to get rid of them but this doesn't look right.
The front has a shimmy sometimes after a complete re-build and a proffessional alignment....
Old Oct 22, 2012 | 06:11 PM
Les's Avatar
Les
I wouldn't use those tires but here's a link that tells you how to determine their age. If they're 6 years or older, even if they look perfect, most tire shops will not work on them and will tell you to replace them.
http://www.tirerack.com/tires/tirete....jsp?techid=11
Old Oct 22, 2012 | 06:53 PM
billcarson's Avatar
billcarson
my 10 year old radial t/a's looked good too but could no longer be balanced and were very poor on a damp surface.chuck em.
Old Oct 22, 2012 | 07:41 PM
STL 71 C3's Avatar
STL 71 C3
Thanks!
These are 4304 so I guess 43rd week of 2004, tire shop visit in near future.
To goodyear eagle tires
