floor pans
Old Oct 26, 2012 | 11:55 AM
bmprhmpr's Avatar
bmprhmpr
Default floor pans
Are the floor pans in a vette (78) galvenized sheet metal ?
Old Oct 26, 2012 | 12:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Sheet metal, yes. Galvanized? Don't know.
Old Oct 27, 2012 | 09:58 AM
terry82's Avatar
terry82
http://www.mamotorworks.com/corvette?frame=4.6167
Old Oct 27, 2012 | 09:32 PM
80Baby's Avatar
80Baby
Mine are made of rust.
Old Oct 27, 2012 | 09:41 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Sorry to hear that.
Old Oct 27, 2012 | 10:11 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The pans were just standard ole sheet metal... I've never seen a trace of galvanization on them. I have installed both the imported and the US made pans. Both take about the same amount of patience and skills to install and neither is an easy job. Labor intense for sure.
http://willcoxcorvette.com/advanced_...ds=floor%20pan
Use the coupon code from the sale and you'll save on the prices at that link too..
Old Oct 28, 2012 | 10:57 AM
bmprhmpr's Avatar
bmprhmpr
Thanks for replys. My pans just had a little rust. In the prosess of removing factory coating it was tough stuff. Used aircraft paint stripper to get top layer off but under that was a black coating which was really tough. Took 2 coats og stripper and sanding with 80 grit to remove. Now Im going to put a layer of zinc phsphate and coat with POR15.
Old Oct 28, 2012 | 03:24 PM
Lou64's Avatar
Lou64
What year did they change from fiberglass to metal?
Old Oct 28, 2012 | 03:41 PM
terry82's Avatar
terry82
Old Oct 28, 2012 | 04:00 PM
Lou64's Avatar
Lou64
Just because I can buy a steel pan that will fit a 75L doesn't mean that's when they were changed. I can buy fiberglass headlight buckets for a '63, but that don't make them original.
Old Oct 28, 2012 | 04:32 PM
terry82's Avatar
terry82
1975 was the year that they went to cat converters .so they needed the metal pans.
Old Oct 28, 2012 | 04:41 PM
Lou64's Avatar
Lou64
Makes sense
Old Oct 29, 2012 | 04:41 PM
Street Rat's Avatar
Street Rat
My floor pans in my '81 are definitely galvanized.
Old Oct 30, 2012 | 09:44 AM
bmprhmpr's Avatar
bmprhmpr
I believe mine were also (78). They had a white crust type of stuff where there was rust. I was asking because I was wondering how well the POR15 would adhere to the metal.But I wire wheeld,and sanded to bare metal all the floor pan surfaces. Galvanizeing is just a coating on steel,Right?
Old Oct 30, 2012 | 10:06 AM
Easy Mike's Avatar
Easy Mike
1976. 75s remained fiberglass but had additional temp shielding for the cat con added.
Old Oct 30, 2012 | 10:46 AM
SuperBuickGuy's Avatar
SuperBuickGuy
galvanizing is simply a zinc coating. Zinc coating is a sacrificial metal used to protect steel. Zinc will corrode and leave the underlying metal intact - for awhile. Eventually zinc-coated parts will lose their coating and the metal underneath will rust - how long depends on how much moisture gets on it.
also, other fun uses of galvanized metal. Did you know that if you lay strips of galvanized steel on your roof (at the peak) it will kill moss? eventually it'll fail (10ish years in the PNW) when the zinc is finally, completely washed off.
Old Oct 30, 2012 | 03:16 PM
bmprhmpr's Avatar
bmprhmpr
Interesting !
To floor pans
