Door Will Not Open
Old Oct 29, 2012 | 10:06 AM
SLAZ06's Avatar
SLAZ06
Default Door Will Not Open
I accidentially closed the pass door with the lock **** between locked/unlocked. Now the door will not open, the lock **** will not turn to unlock. I have the door panel off and can see the part of the lock moving, but it does not release the striker latch. Any ideas or suggestions welcomed.
Old Oct 29, 2012 | 11:09 AM
Peterbuilt's Avatar
Peterbuilt
Push down on this part...
Old Oct 29, 2012 | 01:29 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I'm confused. Unlocking the door does not open it. Once it unlocks, it should open with the door handle.
Old Oct 29, 2012 | 01:59 PM
Billysvette's Avatar
Billysvette
Mine did this,i saturated the lock mechanism with liquid wrench silicone spray ,it freed up the lock and i have never had a problem since.Just use the straw on the spray to direct the spray inside at the lock mechanism. Soak it good.
Old Oct 29, 2012 | 03:29 PM
my 76 ray's Avatar
my 76 ray
Where were you when I needed that picture 2 weeks ago??? I figured it out without coming to the forum but that picture would have saved me about a half an hour.
Old Oct 29, 2012 | 03:33 PM
SLAZ06's Avatar
SLAZ06
Thanks for the replies. I already put so much WD on the lock I was reported to the EPA for creating an oil spill situation. I'm going to try pushing down on the part in the picture. It's a little hard to relate the picture of that clean lock assembly to the one in my 74 door.
Old Oct 29, 2012 | 04:19 PM
'Bochawa72's Avatar
'Bochawa72
Also check out those little L-shaped rods...they should be straight and not bent. Mine got bent from the lock sticking over and over.
Old Oct 29, 2012 | 05:30 PM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
You dont have to push that latch hard, and you only have to do it once.. As soon as you push it down the lock moves to the unlocked position
To Door Will Not Open
